Re: Response to several comments
Bill Turpin in WNC mountains
>The switches are not in parallel. Only one is in the circuit at a time.
My switch is a three position switch with off in the middle. This would require TWO accidental clicks to have a disaster. To prevent such a disaster anyway, put the unused pot at zero speed before changing to the other pot.
Walter's diagram with a one pole switch has both pots in the circuit at all times.
Jack: On another conversion on a mini lathe I learned the hard way to leave the original OEM stuff active and unchanged. Although a totally moveable remote station is nice it can be unsafe also if it overrides stops, etc that are no longer active or are mounted somewhere else.
Just about any supplier that has the pot and 3PDT should have the shielded wire also.
I have ammended my drawing to show the open contacts. For safety do not change pots while the lathe is spinning.
As always it is so difficult to explain electricals over the web. So please take the ADDY proticol.
