Peppermill Drilling
Peppermill Drilling
Peppermill Drilling
Eric S
>I'm trying to make some pepper mills as gifts. The question I have is what spindle RPM and advance rate to use? It seems no matter what combination I try I'm overheating the bits (brand new). How long should it take to drill the holes?
Thanks
Re: Peppermill Drilling
Chuck Engstrom
>Hi Eric -- My experience is that moderate speed and moderate feed are best -- maybe 300 rpm and (just a guess) 4 inch per minute feed. You have to back out your bit frequently to clear the chips, which many less expensive bits do poorly if at all; the build-up of waste can generate a lot of friction and heat, and increasing the rpm's or feed will only aggravate this.
I don't have any experience with fancy bits that are about $30 each, though I've heard that they are much better in many respects, as they should be for the price.
Best--
Chuck
Peppermill Drilling *LINK*
Fred Holder--MW
>I recently had the opportunity to use one of the Colt MaxiCut Forstner Bits. The one I had for test was a 35mm, which is about 1-3/8 inch. I found that it drilled into endgrain just about as fast as I could turn the crank on my lathe tailstock. You do have to back out occasionally or the chips will build up until it is difficult to remove the drill; however, the chip build up did not slow down the drilling. I believe that Packard Woodworks and Woodcraft Supply both carry these bits.
More Woodturning web site
Doc Green
>Eric, I normally use an RPM between 400 and 700 and a fast feed rate. I may turn the handle on the tailstock once per second, which would correspond to a feed rate of about 4 inches per minute.
What you want is to get shavings from the bit instead of dust. Woods differ in how they cut, so some experimenting may be required.
And as has been said already, the chips must clear by themselves or you must clear them.
Good Luck, ~Doc
compressed air
>Eric,
Some years ago I started using compressed air while drilling and it makes a big difference in keeping the bits cool. I blow air wide open in the hole behind the bit during the entire operation. It helps keep the chips cleared out as well. This may be common practice, but I've never seen anyone else do it (until after they saw me).
The other thing I did was buy a set of carbide tipped forstner bits.
As for the cutting speed, I try to keep it just cutting. Some woods cut quicker.
Thank you
Eric S
>Thank you everyone. I tried again this afternoon with much better success. I lowered the RPMs from the mid 500s to around 270 and was able to drill pretty well and straight I got shavings this time instead of dust. My original advance rate was a lot slower and there was a lot of resistance. I was drilling into some tight grained black cherry. I was backing out the drill to clear the dust/chips.
I will be rigging something up to blow air in around the bit. These are a lot of fun to make.
