Spot the Wave
Spot the Wave
Spot the Wave
Tery Scott
>Ancient kauri once again 600mm square textured dot by dot with a Dremel copper leaf applied then various milk paints then sand blasted through the layers of paint ,which had 2 coats of each color and let to dry in between
sold to Collector in Hawaii
Comments welcome
More in this series can be seen under winged bowls in my web site
Cheers
Re: Spot the Wave
Re: Spot the Wave
Don Evans
>Excellent as usual Tery. What do you use in a case like this as your sandblasting medium? I would go with glass or walnut, do you have a different option over there? I guess one could use the old reliable alum oxide also.
Don
Re: Spot the Wave
Re: Spot the Wave
GaryG in MD
>Nice work, Terry. Interesting to hear your order of operations. I like the contrast between the exterior and the beautiful wood interior -- nice undercut too. ...Gary
Re: Spot the Wave
Re: Spot the Wave
Tery Scott
>I did use silica but have just changed to glass
I have a real problem in that my 16 cfm compressor wont keep up and I dont have three phase This is the biggest I can run single phase
It takes forever to blast anything
Thats for taking the time to comment
Re: Spot the Wave
Re: Spot the Wave
Tery Scott
>Thanks Gary
Re: Spot the Wave
Re: Spot the Wave
Don Evans
>I would think that 16 cfm would be ok, I wonder if your problem isn't the size of your tank? I don't have a problem with my compressor keeping up (it is 19 cfm) but it's 80 gallon tank. I'm also using a pressurized sandblasting tank, it's small which in our case is better.
Don
Re: Spot the Wave
Re: Spot the Wave
Tery Scott
>Thanks I ll look into it
