>I live in a small subdivision in an somewhat rural area in NorCal and my shop is closer to the property line/ fence/ neighbors than it should be. I am remodeling my small modest shop and am going to be hanging some sheet rock soon. What can I put besides insulation and sheet rock. I thought of a couple of solutions: Using the metal zbar that sheet rockers use on ceilings so the sound does not transfer directly through the studs, or using sound bard behind the rock, but at $8 something a pop (on top of the rock) I just wanted to check in with the crew to see if any of you have sound proofed your shops and what works, or what does not. Also should I do the rafters as well... adding more cost. A little bit at a time would not be as bad.
One method I have seen is to use a 2x6 plate and header, (or you could fir out an existing wall) and then use 2x4 studs. The studs are set up so that the ones suppporting the sheetrock are set flush to the inside of the plate and the ones supporting the outside wall are set flush to the outside. Therefore there is no direct connection of the inside and outside walls. Takes more studs but you could go with 2x3s and 24" spacing if you are working with and existing wall. Also allows room for more insulation.
>Mine is a building build just to be a shop, in other words not a converted building. It is standard home construction, 2x4's with vinyl siding with the required insulation. There is only one room build inside in a corner 9 square feet and that houses the air compressor which is large 80 gal upright. Did that so could close the door on it if it is running.
20 feet away is the house and when wife is on porch she says she cannot hear anything running inside, this includes the stuff that makes most noise like mitre saw, table saw. Dust collection is Onieda cyclone. No worry with lathe or bandsaw or drum sander as noise is low on those.
One difference is that there are only 2 small windows and one set of glassed double doors. I don't like nor have never liked natural sunlight with the glare for a wood shop. I know that goes against the grain but that fact helps with noise surpression.
So, I don't see a great need for anything but regular construction, which here would be 4" bat insulation in walls and ceiling, drywall inside on walls and ceiling. Outside is particle board wrapped in tyvex and the siding.
Unless your neighbors house is extremely close to the building, if not I wouldn't worry too much about it. You can always put egg cartons on the wall, only kidding.
>One of my friends put "blue board" insulation (okay, maybe it was pink) between his studs and his drywall. Seemed to help a lot. On a similar note, maybe if you put "firring strips" of the insulation foam that might work in conjunction with other insulation batts in the wall.
Sound is absorbed when its energy waves can be dissipated into something else.
Your sounds that you will be making will be a higher frequency, thus frequent & weak sound waves. The absorbing material must be fairly flimsy to absorb these waves. This includes most materials that are easily flexible with small fibers. Spongey foam, fiberglass batts or panels, blow cellulose are great energy absorbers. Rigid foam, plywood, drywall are too rigid to absorb much energy.
Unfortunately, drywall is a great sound reflector and will make the inside louder. Anything soft in the walls will help keep sound from transmitting thru. Fiberglass or blown-in insulation are good candidates. If you look in some commercial enviroments, you will see fabric covered panels added to the architecture. These are often fiberglass panels placed to absorb, rather than reflect the sound off the wall (the room was apparently too "boomy". You might experiment with these in your shop. Will be easier on you too. Many of us have had shops or worked in houses under construction where the fiberglass insulation was hung, then drywall went up. The room became more noiser and transmitted sound easier after the drywall.
Sound will also leak out any available crack.
Good sealing doors and windows are a must. Sound will also transmit thru single pane glass, but does poorly thur thermo-pane glass.
As always, it is much better to try to capture sound waves at the source. Installing foam rubber pads on the inside of your enclosed base machines does absorb sound from the machine. You're kinda screwed with hand tools like routers though.
I like the idea of getting your close by neigbors some peace offerings before you get too deep into the shop work. Also, other than hot summer evenings, they have windows & doors too.
>Chris What are the sound problems. I would work on that source first. For example my dust collector air compressor and chainsaw are my main sources. The dust collector is inside so the neighbors don't hear it. I turn the compressor off whenever I'm not there or at night. I only use the chainsaw after about 10am on the weekends and try to keep it to a minumum in the evenings unless I know they aren't home.
My biggest problem is the radio. Sometimes I like to crank it up. I've been thinking about putting a foam cone around it to direct the sound toward me. It's on an outside wall and I was surprised how much you could hear it through the walls.
>I did see a 'sound board' product at my local big box store once. Looked like it was about 1/2 to 3/4 inch thick, and soft particle stuff, intended to go on the studs before putting up the sheet rock. Fairly cheap. The only real noise maker I have other than the chainsaw is the planer. I don't use it at night, and try to use it mostly mid day as to not be too noisy. Unless you are spending long hours, it isn't much of a problem. You might talk to your neighbors and ask for their input.
