OT: router table
John Scheideman
>I just bought the Triton 3 1/4 HP router to use in a router table. Now I need to decide what router table setup to get. Any suggestions?
Thanks. John
OT: router table
John Scheideman
Thanks. John
JoinTech Cabinet Maker System
charlie belden
>Don't know about you, but I'd rather make furniture and boxes and things like that, rather than make stuff in order to be able to make furniture and boxes and things like that.
So, early on, I bought the JoinTech Cabinet Maker System And a table top with the router insert space already cut out - and got the insert and the set of "rings" to go in the insert to accomodate a range of bit diameters. Used that set up sitting on an old kitchen cabinet carcase to make a real router table, with drawers and a cabinet door for the space the router fits in.
I'd recomend the JoinTech over the Incra for a couple of reasons.
1. the cabinet maker fence body is hollow extruded aluminum with
T-slots for attaching things to it - like stops and vertical feather boards as well as what JoinTech calls a Vertical Push Fixture (think router finger joints of dovetail tails wiht the part vertical)
2. The front face of the fence is actually a "split fence", two pieces, between which they provide easily replaceable zero clearance inserts which you can cut with the bit you're using - say for rail and style, lock miter or raised panel bits. This means that there are NO gaps around the bit - so a part can't possibly get behind the fence where trouble lurks - waiting.
3. Each of the split fence faces can be moved out away from the other one - handy for trueing up an edge if you don't have a power joiner or a hand plane joiner. Also comes in handy with profiles that need a knife edge that you have to sneak up on - and can easily overshoot. With those, at and passed the cut may produce an edge that has a slight step in it when working with the part horizontal. Before the bit you've got your original edge. At and passed the bit you may not. So at the end of an overshot pass, the outfeed, narrower part slants a little to contact the fence face - and you don't end up with a straight edge - but a slanted one, often with a bit of sniping at the end.
Re: OT: router table
>Build your own. I used a piece of 1 1/2" MDF but you could just as easily laminate 2 layers of the thinner stuff and maybe put a few cross pieces of solid wood to stiffen it.
You can purchase the plastic to mount the router on. I think I bought mine at Highland Hardware. I put grooves in for a miter gauge but I've never use it. I use rectangular waste blocks for routing the end grain on pieces because you need a backer piece of scrap wood to prevent tearout anyway.
I built the fence from Plywood. I put clamps on both ends. You can loosen just one end to make extremely find adjustments.
>I am jealous of Charlie's set up on this, but I went with John's idea. I went to a cabinet shop and got two "sink cutouts" from plastic laminate counter tops. I put bolts in the edged that matched the holes in the wing of my Table Saw and glued the two pieces back to back. This created balanced construction and canceled any tendency they had to warp. (and they do warp). Cut them to size and mounted then on the end of my TS. The fence rails support them. Cut a hole in them and lines it with hardwood strips to use for the router. Mounted the hardwood low and put screws in the top edge to support the router base plate. Then the screws can be adjusted to keep the plate flush with the top. I used hard board for the plate, but would not recommend it. Buy a base plate and fit the hole to it.
The fence for the TS works for the router, but it is not as handy as I thought it would be. It seems that just when I get it set exactly where I want it, I need to rip something, so I often use a straight piece of wood as a fence. This has all the ad=vantages and disadvantages of any multi-use tool. Constant change over. It does take up less room in my small shop, but a dedicated router station would be better in a roomier shop. I struggle with the "I could buy a "Blank" but then where would I put it?" problem.
The two sink cutouts are a great starting point if you make one.
Re: OT: router table *LINK*
Rob Wallace
>I can recommend a few sources for Router Tables and accessories for you to consider:
Woodhaven (link below) is among the best, in my opinion. Excellent workmanship in their products, and well thought out designs....
Kreg Tools (www.kregtool.com/products/prs/index.php) has also been recently producing some excellent Router tables. I've been to their factory several times and they produce excellent tools. I have one of their miter gauge systems and it is "precision".....
For at least 17 years, I have been using a router table top from Eagle America (www.eagleamerica.com), and it has worked reasonably well, although its fence system I have is really out-dated, with much better systems available now than there were when I bought it in the early 1990's. I am contemplating an upgrade of my router table system (or at least the fence) from either Woodhaven or Kreg - the problem is that I do so much turning now, and relatively little flat work, that the investment in the new router table system doesn't seem very logical, nor high priority. I'll wait until there's a very good sale on one of these systems some time in the future I guess.
Regardless of the system you get, you should also consider the table's compatibility (and adjustability) with above-the-table router adjustment/raiser systems, because if you use a router table often, you will definitely want to have this ability.
Good luck in your search!
Rob Wallace
Woodhaven Router Tables and Accessories
Don Evans
>Rob one of the great things about the Triton is you have a built in router lift with it. Only have to drill a round hole in the plate and that is it. Also the collets require only one wrench with the self ejecting of the bits.
This is, in my opinion, one of the best if not the best router on the market.
I hope they keep building them, I got the 2 1/4 hp model and cannot imagine needing more power.
Great tool and I have no stake in Tritons business other than I want them to continue so they are around when I want another one.
Don
Re: JoinTech Cabinet Maker System
Kirk (KC) Constable
>I have the JoinTech table also. I like it because the phenolic top is flat and the steel stand (from them) is very sturdy. I like the micro adjustment on the Clincher system for sneaking up on cuts. The split fence is conceptually neat, but I've never been able to adjust mine 'perfectly'. Always a 'bump' between the two parts. Still the best fence I've used, tho.
Brian McKearney
>I'd highly recommend the Bench Dog ProMax if you have a table saw. It replaces the left-hand wing of your table saw with a top quality cast iron wing that has a cutout for a router. Comes with a pretty good fence of it's own.
I have had mine for a few years now and I'm very pleased with it. And it doesn't take up any extra space in my shop.
Brian
Wayne Fladby
>I too have the big Triton router. I bought the insert from Incra because it was the only one I could find that was pre-drilled for the
Triton, then I built my own table and stand. This is the third router table I have built and having the pre-drilled insert was a bonus.
BTW I was at a Christmas/Open House at one of the better tool dealers here, and was talking to the rep from Freud (my favorite bits btw), and he said that Triton has gone belly-up in Australia! Anybody else hear anything -confirm or deny
John Scheideman
>I guess Triton has gone bankrupt in Australia but their US distributors are still operating. No one seems to know for sure what will happen. I read somewhere that they are trying to sell out to someone else. I hope they stay in business somehow. They make a good router. Wayne-- what kind of fence did you put on your router table? And what would you do differently if you did it again?
Thanks for the help.
John
Wayne Fladby
>Hi John -my router table is made from a piece of 3/4 baltic birch ply.
I painted the bottom with melamine paint and put a piece of Formica on
the top. The fence is made from 2 pieces of 3/4 ply, clamped at both
ends like John L has said. Adjustment is made with whatever I have in
my hand!! No miter gauge and no miter slot, but it is a work in progress and subject to modification if the need ever arrises.
You are absolutely right about the Triton being a good router. I own
four routers right now (no cheapos) and consider it one of the best.
