Safety Tip: Chuck Jaws
Doc Green
>Some say it's a good idea to remove the sharp edges and burrs from the leading edges of the parts of the chuck jaws that may extend beyond the hub of the chuck. This way, when you get into the jaws, little if any damage is done.
And you will get into the jaws. Experience indicates that you are much more likely to do it when sanding as opposed to more glorious endeavors.
The burrs can be removed with a file, or you can open the jaws and touch the corners with a sanding pad (150 grit) on a drill. However, if you use the sanding pad, be careful not to let the sharp corners tear the pad. It's better to knock off the burrs with a file, then sand.
Respect the chuck jaws. ~Doc
