If you own 60 grit sandpaper, safety is an issue
steve antonucci
>It might sound condescending, but a good earmark for safety training is where you start sanding. If you have to use 60 grit sandpaper, odds are that you can benefit from a lesson or two (and a lot of practice) that will greatly reduce safety issues.
Aside from the dust issue, tearout is usually cause by tools being presented incorrectly, dull tools, or off bevel- all which greatly increase odds of catches, airborne wooden projectiles, and bodily injury.
There is an unconscious list of things I check every time I step up to the lathe-
Is the tool sharp?
Is the wood free of defects (od do I know what defects it may have)?
Is the wood securely mounted?
Is my lathe speed set properly?
Will the wood spin without hitting the lathe?
Can I reach the powerswitch if I need to? (I have one on either end of the lathe)
Am I OK to be in the shop?
Is there anyone home if something bad happens? Do I have a phone close by?
Am I out of the line of fire?
Is there anyone else that might be in the shop and in the line of fire?
Do I have the proper tooling to make the next cut? (7" over the toolrest with a bowl gouge means NO!)
and the list goes on...
S
