A cautionary story
A cautionary story
A cautionary story
Mike Foster
>I was driving to an interview yesterday when I noticed smoke and a whole lot of gawkers at the bottom of our road. Across from the road a nice 100 yr old barn was up in flames. The posts and beams were still standing, but it will be a total loss. My heart immediately sank for the owners. I've experienced a fire, and it is awful no matter what. We live about 1 mile from our local hospital and when I returned about an hour later we noticed a helicopter circling more than usual. It finally did land. Looking in the paper, it was indeed a flight for life, but not the normal one that flies to Dartmouth/Hitchcock, but one from Boston that did not know the hospital. They were taking a victim to their burn unit. Apparently a man is in serious condition from burns to his hands and face. The story noted that this man was in the barn cleaning some tools with naptha. They did not know any more details regarding what may have caused the explosion that started the fire. It only takes a spark with such volatile solvents. I have to confess that I have some naptha, but only use it outdoors where there is no chance of sparks. Naptha is a good solvent to remove wax (if you have waxed a piece and want to remove it to refinish or touch up a finish). I always feel uncomfortable using such solvents for their reactivity and possible health effects. I always use these outside and wear charcoal filtration masks when doing so. Be careful and safe.
Re: A cautionary story
don lewonczyk
>When I was stationed in Morcco (1959-1960) I worked in periodic maintenance and on of my jobs was to inspect the jet intakes for cracks, loose rivets,etc. The intakes had to be cleaned first and that was done with naptha, no rubbed gloves, no resperator, no protective clothing,no warning labels. Here's the rags and solvent so get to it,no wonder why with all the other crap I was forced to use that my health is the way it is. The guy cleaning the tools could have lite up for a smoke break and bammmmm! Take Care, DonL
>Don We used to mop the radar tower with Trichlorethane. No protective gear whatsoever. We would hold our breath and go in and mop as fast as we could, run out take a breath and go back in an do it again. They pulled that stuff off the market because it caused cancer. It was also very flammable and of course everyone smoked back then.
Ric Taylor
I Was There
Ric Taylor
>Sidi Slamane Air Force Base, Morocco 1954 - 1957.
Ric
Jesper, Denmark
Jesper, Denmark
>John, it is nasty stuff from a health and environmental standpoint, but not flammable in air at ambient temperature. That was the very reason it was used so much for de-greasing applications.
To make it burn, you have to heat to high temperature in an incinerator, and there is breaks down into chlorine gas and water, then later the Cl is combined with the water to make HCl, hydrochloric acid.
Still nasty stuff, but not a fire hazard.
