Woodcraft Diamond Wheel
Scott Hurley in N VA
>Has anybody tried the new Woodcraft diamond wheel on their grinder? If so, what do you think about it? Does it clog up and need to be cleaned, and how do you clean it, if needed? Thanks.
Scott
Scott
Re: Woodcraft Diamond Wheel
Harvey Meyer in Atlanta
>After trying the wheel out at the Atlanta Woodcraft during a club turning event, I bought the 120 grit diamond wheel about 2 months ago. It doesn't grind your tools - it "almost" hones them. You'll still need a 46, 60, or 80 grit wheel for grinding. What it excels at is "almost" honing an edge. I use it to touch up a tool when it needs resharpening. As long as you're not changing the profile of the tool, it will sharpen the edge to almost mirror finish in a few seconds. It leaves an impressive edge on the tool. If you try to grind the tool, as you would with a lower grit grinding wheel, you'll find it to be a frustrating experience as it would take hours to grind away any considerable amount of steel. The good thing is that when you use it to just touch up the tool, it removes virtually no steel. Your tools could last several lifetimes. I suppose you could get similar results with a 120 grit aluminum oxide grinding wheel, but I haven't tried that.
So far, my experience has been good. The wheel does not clog easily and when it does, it's easy to clean with one of those big gum erasers that we use for cleaning sanding disks and belts. I just lightly rub the eraser on the wheel as it's spinning down and it's good as new. I set up my grinder with a 46 grit Norton 3X wheel on one side and the diamond wheel on the other. I may replace the 46 grit wheel with a 60 grit as I really don't have to do any drastic changes to the profiles of any of my tools. But I'll wait until I wear the wheel down enough to justify the change.
I give the wheel 2 thumbs up.
Harvey
bernie feinerman
>I have some Craftsman carbide tipped turning tools and wonder if you have tried to sharpen any carbide tipped tools on the Diamond wheel?
Cindy Drozda
>I have had one of these wheels (120 grit they call it) for several months. When I am sharpening with the tool on a platform, I like it a lot. It puts a finer finish on the edge than my 120 grit 3X wheel. It is also nice for small tools that I want a precise profile on (as well as a super-sharp edge).
It is much slower to remove metal, so is not efficient at all for reshaping an edge or changing the bevel angle.
When grinding free-hand, I find the diamond wheel hard to use because it doesn't seem to give the "sparks coming over the edge" effect that tells me when I have the bevel ground up to the cutting edge.
Diamond gives a sharper edge to the "powder metal" tools, such as Thompson, Hamlet 2060, CPM10V, A-11, etc. Technically, aluminum oxide doesn't sharpen these steels properly, but diamond does. I am very pleased with the edge that I get on my Thompson tools and recommend this wheel to anyone who uses these tools.
When I first bought this wheel from Woodcraft, I asked them to find out for me whether I needed to dress the wheel and how to do it. The manufacturer of the wheels came back with a reply that dressing or cleaning was not ever going to be needed. I can also say that the wheel seems to be properly balanced as far as I can tell. I do, however, like the idea of cleaning the wheel and will take the suggestion about using a belt cleaner. Thanks for the tip, Harvey!
It's nice to have a fine grit wheel that is always flat and square, and never gets distorted or dished out from grinding. I miss my 120 grit 3X wheel, though. I really need to have the diamond wheel for fine work with my Thompson tools, and the 3X for when I have to sharpen a lot of tools fast (like preparing for a class).
>Thanks for the quick responses!
Scott
Jorge Castaneda~Downeast Maine
>Cindy,
I don't have a diamond wheel yet, and have a bunch of Thompson tools, so it will come.
I do have a diamond file with rounded edges I got from Alan Lacer a few years back, 600 grit still going strong and I do hone my gouges. Alan recommends to use soapy water now and then to keep it clean. So maybe that will work on the wheel too.
Jorge
1800 or 3400 RPM
Brent Smith in Montreal
>Cindy, are you using this wheel on a slow or regular speed grinder??
I clean my hones with spit and a paper towel
steve antonucci
>probably easier to use soapy water on something as big as a wheel, but same idea. Doesn't take more than rubbing with my finger.
S
