Shaker candle stand
Shaker candle stand
Shaker candle stand
>I built this today along with the candle stick and candle. It is a gift for my sister for Christmas. It's cherry. The candle stick is mahagony and candle is yellow heart.
Re: Shaker candle stand
>OK actually this is a mockup for the original full size version that I'm going to start on tomorrow. The real one will be made out of Walnut.
JohnKyler
>Looks nice. It even made Lincoln stand on his head.
Dick Coers
>Very nice John. I sort of thought the proportion was a little off on the legs of the stand in pic one, but then chuckled when I saw pic 2. I wouldn't be surprised that the miniature version could be just as lucrative as the full size. Those miniature collectors can spend the cash.
>Dick I thought I got the legs wrong also. They look to thick. I'm going to make a full size cardboard mock up of the legs to check that. I'll make the center spindle today and get the top glued up. Then I can check the shape of the legs.
I'm I'm going to make miniatures like this I need smaller router bits for my dremel. A miniature router table would be awfully nice also. I had a very hard time fitting the legs. I did make a miniature chisel for squaring up the mortise in the legs.
Mike Foster
>You had me John, until I looked at the second picture. Nice job on the details of such a small piece. How did you mortise in the legs?
Leg Mortising
>Mike I use the Dremel on the same platform that I use to route flutes. I put the index wheel on the Lathe and locked it every 120 degrees. I don't have a dovetail bit that small so I had to just route a straight mortise. I ground a jewelers screwdriver to a chisel and squared up the ends of the mortise and cut one of them deeper. It is quite challenging because you are trying to take cuts as small as 5 to 10 thousands of an inch.
Keith Tompkins
Keith Tompkins
>WOW! That's a big penny! Sorry John, couldn't resist.
