>Hope that you guys can help. A few months ago i made a ice cream scoop using black palm for the handle. The ferrule was glued in place with superglue. Couple weeks later the ferrule fell off it was very loose, when installed it was a tight fit. People who saw it liked it and it has been requested as gifts. Is there anything that i can do to prevent the ferrule from falling off at a later date. It is embarrassing when you get that phone call that starts with guess what______. Thank you john b.
>Look at the ferule on your wood handle turning tools. You will notice small dimples in the ferules. You can also burn the moisture out of the wood. You can use a small torch (like is used in cooking) to burn the ferule area which will shrink up that portion of the wood.
Turn the ferule area a bit large (as much as 1/4 extra thick).
Burn that portion of the handle so that it is bone dry.
Turn to the correct size
Epoxy the ferule on and dimple the ferule into the wood.
You can burn the wood with surprising accuracy using the little torches
>Don't know if you did or not, but recommend roughing up the inside of the ferrule with sand paper to remove any finish and to give the glue something to bond to.
>John, was the palm wood fully dry? I have not turned black palm, but my experience with other palm wood is that it shrinks drastically as it dries--much more than most hardwoods. Perhaps this was the problem. Dennis
>You have to remember that you are basically turning a grass. I think the other suggestions will help, except for burning the palm. I think that stuff will go up into flames quite easily. The soft sponge between the needle-like shards must char really fast. How about a tenon of hardwood drilled and inserted into the end of the palm. No idea that will help with the weak wood or shrinkage either.
>I just made some pens (two out of four tries) with black palm. A very flaky, brittle wood (the piece I used, that is) that I would not use again. The inside of your project probably "flaked" away and you're having trouble getting a good fit. Good luck.
>John I've been making things with Ferrule's for a long time. The only way I know of to make sure they stay on is to either have threads on the inside or pin them. Even putting dimple in them won't gaurantee that they stay snug although they might not fall off if the dimple is big enough.
You can super dry the tenon. The green chair makers do this by putting the tenon in hot sand and drying it until it doesn't shrink anymore. This works really well on chairs because when the tenon takes on moisture to get to it's normal moisture content it locks the two together. It tries to do the same with the metal but the metal doesn't give so it tends to crush some of the fibers. Eventually it still comes off. That's the concept behind burning the wood but burning only dries the outer layer and in the case of the Palm it will probably burn the stuff to pieces.
I have had pretty good success with really roughing up the inside of the ferrule with course sandpaper. Then I dry and rough sand the tenon as well. I use epoxy to put the two together. That's lasted about as long as anything.
When making my own ferrules I will use brass compression nuts. They are threaded on the inside. I turn the tenon so I have to use a wrench to screw the nut on. Then I turn this down to round. Those don't come off.
The other method I've used is to make a brass ferrule out of pipe. Then I drill through the side and put a brass pin in it. Once this is turned down and polished you can barely see the pin. If the pin extends into the drilled area you may have to file or re-drill that part.
>Take the entire piece of "Black Palm" and soak it in Epoxy Resin. Palm is nothing but a bunch of hollow tubes held together with other fibers. If you use Epoxy Resin and thin it with whatever is recommended by the mfg, the Palm will suck it up like a desert-dry sponge.
>Thanks for your prompt response. When i first installed the ferrule it was a press fit. The amount of slop around the tenon weeks later is about 1/32". I am thinking of rough turning and drilling the blanks and placing them under a 100w light bulb for a length of time. Roughing the ferrule and using epoxy for the installation. Then i am going to use different hardwoods for the other pieces.
