Grizzly model G0462
Ernie C.
>I'm looking for some feedback on Grizzly model G0462? I'm new to turning and concerned that the 2hp lathe max rpm is only
2400.
Grizzly model G0462
Ernie C.
2400.
Re: Grizzly model G0462
>Unless your only going to turn pens 2400 rpm is plenty.
Dave (PacNW)
>I have looked at the Grizzly Lathes in thier showroom and have not been impressed! I would Recommend a Jet, Rikon, Or a Nova over a Grizzly any day of the week. They cost a little more but you get what you pay for. The better brands hold their valve better as well a perform better and smoother. I have a Jet 1642 1 1/2 HP variable speed and the only way I would part with it is for a ONEWAY 2036.
Just 4 cents worth (adjusted for Inflation)
Dave (PacNW)
Frederick Nelson
>The Grizzly G0462 is their version of the 16 x 42 lathe. It also bears a strong resemblence to the JET 1642 variable speed lathe, and "resemblence" is about all it can claim.
Better choices in the same size range would be the JET in both 1.5 and 2.0 HP versions, or the Laguna 18 x 47 electronically variable speed lathe. Both are good lathes, with the JET having a better reputation. I've had the Laguna about six months now and have completed a few smaller projects on it, and I'm quite satisfied with my purchase. Once I've got a few more projects completed, fully putting the lathe through its paces, I'll make a more complete report on the lathe.
The picture of the Grizzly G0462 on their website reveals one serious weekness it its design: the off-set tool rest holder. Stories from others suggest this off-set piece will break at the first opportunity, so it is probably better not to install it in the first place.
As mentioned before, the top speed of 2400 rpm is more than adequate for anything you are likely to turn. That 600 rpm minimum is also likely way too fast for your larger diameter projects.
The best advice I could give on this item is to look elsewhere; there are better places to spend your money.
Fred Nelson
Under clear skies in Eastern Missouri
Tony Latham
>I agree with Fred, the upper end isn't the problem but that 600 is a big problem in my experience... I've got the Jet 1642 and there have been several times with bowl blanks that I had to start out at 400-450 or so...
I think if you just "did it" and bought the Jet you would never regret it.
TL
Re: I have one. . .
Dave Mount
>I bought this lathe a year ago. I bought it knowing all that people have said above, but the reality was I wanted to turn a few things larger than 10" and for the core features (hp, throw, and bed lenth) you couldn't touch any other brand for close to the same money.
Was it a good buy? Yes and no. It is not a top quality machine, and if you turn for the rest of your life, you'll buy another lathe. On the other hand, if you don't have $1,500 to spend on a more refined lathe, this lathe is better than no lathe if you want to turn something larger than will fit on a mini or midi.
While the lathe has a 16" throw, I've only used it out to about 13" or so, and I'd be leery of using it much beyond that. As others have said, 600 rpm is (nominally) the lowest speed and this translates to some serious velocity at the edge of the blank, and if your piece is not well balanced, it can get exciting at the least, dangerous if you're not careful. You need to turn sound wood, anchor it very well, and take great care when roughing the blank on the bandsaw to get the blank well balanced. Not only am I careful to cut an exact circle on the perimeter. but if the blank is not perfectly symmetric, I'll slice off some of the corner to balance it better.
Having heard about the issues with the low end speed, when I first received the lathe I opened it up and fussed with the placement of the pulleys on the shafts to slow the lathe down to about 500 rpm at the bottom end. This was fine at first, but as the belt wore (see below), the bottom speed starting creeping up.
Another problem, with mine anyway, is that the two pulleys (on the motor and on the headstock) are not well aligned. As a result, the belt has to move sideways to go from one to the other, and this creates a lot of belt wear. As the belt wears, it won't ride as high on the headstock pulley and the bottom speed increases. You also have to replace the belt with some frequency. Mine needed a new belt after probably 30 bowls. Grizzly replaced the belt under warrantee, but that will only last so long.
I talked to Grizzly about the pulley offset issue. They suggested I could elongate the holes in the motor mountings to allow me to slide the motor over to improve alignment. I suspect this is a design flaw and not a problem with my particular unit, so I saw little reason to insist that they replace it. If I get motivated, I may work on the motor mounts, but haven't so far (not much shop time in the summer).
I am also a little unsure about the quality of the bearings in this unit. Mine seems to have picked up greater tendency to chatter at the rim of larger bowls. I can't feel any looseness in the shaft, but I think this is the start of bearings going bad. Again, I suspect Grizzly will provide replacements as long as its under warrantee, but in the longer run. . .
I haven't used the offset tool rest, I've just turned everything over the bed. I do have some questions about how sturdy that arrangement would be, enough so that I've never used it.
One other thing you should be aware of is that the hole in the banjo for the tool rest is specified as 1", but it is not. I believe it is 25 mm. This isn't a problem with the stock tool rest, but if you get an aftermarket tool rest, as I did, you'll find it won't fit because the hole is 0.4mm too small. I've been meaning to bore that out, but haven't thus far.
Because of all the above, I've kept my (old model) Delta midi, and continue to use it where the limited dimensions and hp aren't an issue. It's a smoother running machine than the G0462. Perhaps one could argue that this effectively increased the cost and decreased the value of the G0462 because I didn't recover any investment through selling the Delta midi. I wouldn't disagree strongly.
So, do I think it was a bad buy? Not exactly. I think I got what I paid for, which wasn't for a top-dollar tool. Right now, I don't know if bowls were a short-term "craze" or if I will be turning a lot more. If it's the latter, I will probably replace the lathe eventually with one of the units others are recommending. However, since I wasn't ready to spend that much at the time, and because I don't know whether I ever will have the need/desire/willingness, I think the G0462 was a reasonable interim step for me. Just don't go into it thinking your getting the same machine at a third the price. You're getting what you're paying for, which may or may not be the right thing for you.
Best,
Dave
