What am I missing? Safety issues?
russ fairfield
>It seems to me that there are some serious safety issues being ignored in these conversations about using a glove, loose clothing getting caught in the lathe or spinning wood, underhanded techniques as opposed to proper (?) overhanded tool holding, what kind of a bevel we should grind on a tool, and which tool we should be using to make what kind of a cut.
It seems to me that -
IF we are using the right tool with the right profile and presenting a sharp tool properly to the wood, sliding it along the wood surface on the bevel, using the bevel as the pivot to control the depth of the cut, and we are letting the tool cut and make a natural shaving as opposed to forcing it into the wood; then there is next to no force in any direction at the tool rest. Our hand at the tool rest is only guiding the tool, and there is no need for a death grip on the tool to keep it going where we want it to go, there is no reason to have our fingers wrapped around the tool rest, there is little reason to be prepared to control some irratic tool movement such as a catch, and it doesn't matter whether we are using our hand under or over the tool.
If we are not using the tool as described, we are either using the wrong tool for the cut we are trying to make or we need to go back to the basics and learn how to use a lathe tool.
On the issue of gloves or bare hands, I have to ask the question. Why are your hands or fingers anywhere between the tool rest and the spinning wood. If you keep your hands behind the tool rest where they belong, what difference does it matter whether you wear a glove or not. There should never be any reason to wrap our fingers around the tool rest to control a properly used tool, and there should never be any reason for putting your hands or fingers between the tool rest and the spinning wood.
On getting our cloths wrapped around a chuck or a spinning piece of wood - There should never be any reason to reach across the top of a spinning piece of wood - EVER.
Sanding finishing should be as close as we get to the spinning wood, and that should be done carefully while holding the paper or cloth under the spinning wood so any grabbing will pull it away from our fingers, and not pull our fingers into the wood.
Tool storage is also an important factor. Many woodturners build their tool rack on the wall behind their lathe. This requires them to reach across the lathe for every tool they use. It only takes one time while the wood is spinning to get caught up in your work, and don't count on the fact that the lathe might have only 1-HP to save you from some serious hurting before you stall the motor.
Having to wear heavy clothing in an unheated shop is an accident waiting to happen. Besides getting in the way, heavy clothing is often loose fitting, or restricts movement. It we have to work this way, we should use extreme caution, wear cloths that aren't easilly caught on anything that is moving, wait until spring, or put a heater in the shop.
Tell me where I am wrong.
