Big Midas
Big Midas
Big Midas
Tery Scott
>Turned in the rectangle with no waste blocks ,made from new Zealand Rimu not that you'd no
measures 300mm 12inches across the wings .Yes I am afraid I turned the top of the wings with the skew Sorry !! The only way I know of cutting into the cross grain without teh tips and wings going west.
The sound of this spinning makes a noise like a jet about to take off
Great on a hot day
The wings were sealed coated with copper leaf and then with various oil based paints a sponged effect placed over the top
The inside was leafed and sealed
The out side of the bowl was textured with a coiled spring made up to fit my Poker hand piece then sparayed with an airbrush
More of these can be seen on my web site www.timberly.co.nz under winged vessels
Comments and feed back welcomed
Re: Big Midas
Re: Big Midas
GaryG in MD
>Spectacular, Terry. I'd love to watch you make one of those. When will you be crossing the pond? ...Gary
Re: Big Midas
Steven Antonucci
down to 9 minutes of sleep?
steve antonucci
>From the picture, it appears that the lower wings also have a profile to te floor? Is that turned of bandsawn? I'm struggling to see how you would have oriented it to be turned if that's the answer?
S
Re: Big Midas
maybe I'm mistaken,
Thad------WebKitFormBoundaryjR+rDxJJAbIP6FhH
>but couldn't that profile be turned on a 2nd axis?
More accurately, that profile done first (1st axis) followed by the rest of the bowl & wings on another axis.
~ Thad
Re: Big Midas
Re: down to 9 minutes of sleep?
Tery Scott
>Sorry I must of missed something here ,This piece is only turned on one axis being the center of the bowl .The curves on the wings 4 points that the piece is supported on happens naturally when turned
Re: Big Midas
Steven Antonucci
(You seem to produce one of these a day)
steve antonucci
>Also, the lathe is only a piece of it. Post lathe processing has to be equal or greater to the effort. I assume that you spend 15 hours per day in the shop, a few hours eating and such, leaving only 9 minutes left to sleep at the end of the day...
Or do you just not eat and use that time for sleep ;-)
S
P.S. my question was how did you turn the little arches in the wings at the bottom to get it off the table on four points?
