Hook and loop disk?????
RPE
>I am wanting to start power sanding in a non-powered mode. I have begun investigating what to buy. I purchased a die grinder at harbor freight to use as a holder. I bought 2" disk holders from Penn State.
I can't figure out which disks to buy. Cloth, Paper, Film. I plan to punch out my own 2" disk from larger sheets or disks. I find the variance in prices is great. From $.30 a disk to $.05.
Is paper hook and loop okay to use or do I need to get cloth or Vinces film? Vinces blue film pads are $.13 a pad. How many pads will I use on a bowl?
I just don't want to buy and try a bunch of things that are gonna work or give sub par results (my turning will do that just fine!). I just want something that will work. I don't want to spend to little or too much. I don't sell anything. I just give it away to friends and family. I glue a quarter in the bottom of my bowls, so I know they are at least worth $.25! I do a little segmented and regular bowl turning.
Any help in making a decision would be appreciated.
RP
Re: Hook and loop disk?????
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>The sandpaper industry is very competitive. There are no real bargains out there. If you pay five cents for a disk, I can guarantee you will get a quarter of the wear out of it that you would get out of a 20 cent disk. I prefer to buy the more expensive sandpaper. You can sand out the whole bowl with one disk per grade wile the disks are still sharp. I find it gives a better finish and is less costly in the long run than using four less expensive disks and spending a lot of time sanding with dull disks. Also, the better disks do not cause heat buildup and heat cracks the way the cheaper ones do.
Nick Tuzzolino
>Bill, you said it all. Concur 100%
What Bill said :)
Dave Peebles Lyons, Ohio!
robo hippy
>The only discs I haven't tried are the 3M ceramic ones. They are only available in PSA (pressure sensitive adhesive) and I can't justify that for dust magnets. The discs from Vince last as long as anything else I have tried including the Norton Dry Ice Ceramics, and cost a lot less. Call Vince and talk to him about what you need. I do believe he does have his abrasives in sheet stock now. I do prefer the over sized discs, which fit his mandrils. If I can get a 3 inch disc and pad into a bowl that is what I use. If not, I will use the 2 inch ones. Get a good mandril, and then at least one firm pad, and maybe a medium one, and a soft one. Sand at slow speeds, like 600 rpm, and keep the bowl speed down as well. It works better, and is just as fast. A die grinder is way too fast, but there are some who use them.
robo hippy
>I agree with Robbo and the others. I buy the blue discs from Vince. They outlast the other abrasives I've tried cut very clean. Sandpaper is something I used to scrimp on. Not anymore. It saves time and aggravation when you are using a good tool. Sandpaper is no different.
One of the best things I ever did was to decide that turning tools and sanpaper were disposables. That is, you use them up sooner or later. This let me sharpen more often because I wasn't concerned about using up the tool. Consequently I became a much better sharpener which in turn makes my tools last longer. The extra sharpening lets me cut cleaner so I use less sandpaper. Using fresh sandpaper leaves fewer errant scratches that have to be removed later so it saves time and frustration.
I use a file card to clean my discs when they clog from green wood or lacquer. I use a crepe rubber bar to clean them frequently while sanding which makes them last longer as well. I purchased seperate sanding mandrels for each grit which hurt when I spent the money but is one of the best things I've done. I have not had to replace the velcro on a single one have never had a disc fly off.
Cyril Griesbach
>RPE, there isn't any better advice than what you've gotten so far.
Grant Wilkinson
>Pardon my ignorance, but who is Vince?
never mind
Grant Wilkinson
>Sorry about that. I just saw the following thread. I've written WoodnWonders a couple of times, but no reply.
>Great advice in this thread. Read it and take it to heart. Bill Neddow and Robo have sanded more bowls in the last year or two than I have total.
What I want to add to my collection is mandrels that have the quick release hex shafts. Then I would have one for each grit. That way you are not constantly pulling the paper off and putting it on. The constant changing leads to wear of the hooks and loops and trash gets on the back of the sand paper.
Use good stuff, use low speed on the bowl and the disk, use a light touch, use the sandpaper like you bought it with somebody else's lottery winnings, establish which grits you will use and then step through all of them.
Thank-you
RPE
>I want to thank all of you for taking the time to respond to my thread. It is good advice. I have to get busy and build my 20" disk sander and then get to turning. Thanks again
RP
Re: never mind
Vince Welch
>HI Grant,
I am sorry if we have missed each other. I just read your post. I have been making some changes to the site I have new products coming in very soon such as Micro Mesh.
Please call me toll free at 1-877-284-8969 and I will be happy to help you however I can. Thanks, Vince
Re: never mind
Grant Wilkinson
>To be fair to Vince, since I posted my previous message, he has contacted me twice by email to help me out. Can't ask for more than that.
