Eureka!
Keith Tompkins
>I did a bit of turning, comparing the two skew grinds in question in my previous post. I believe I've discovered WHY the two grinds behave quite differently. First, illustration "A" shows a conventional ground skew chisel. The dotted red line shows the relationship of the grind to the turning stock. I have concluded, since the double bevel is at an angle to the axis of the tool, raising or lowering the handle has NO EFFECT on the edge's approach angle of the tool. The top bevel will always be angling downward, no matter the tool handle height. Only when the handle is swung to an extreme angle, as in the image on the far left, will raising or lowering the handle have any effect on how the bevel approaches the cut. In this position the tool is useful only for a peeling cut, in small increments. The advantage of the skewed edge is lost. Illustration "B" shows a skew with only one bevel, notice the different top edge approach from "A".
The main factor here is the skewed edge....if both tools were ground straight across, they would behave exactly the same, as one would expect. The only difference would be tool handle position.
I think this shows a clear, distinct difference in the two grinds. What do you think?
