Inverter
Inverter
Dick Hines
Inverter
Dick Hines
>I have heard people talking about the static that their inverter causes to their AM radios. Today I was sanding a bowl and decided to ride up to the store for a drink and snack. I sprayed the bowl with a coat of sanding sealer and walked out of the shop. When I got in the truck the AM radio was going mad. I stoped at the end of the driveway. A good 200 feet from the lathe and the radio was still going mad.
What interest me is that may shop is fed off my house service panel.Throught the meater base and then through a step down transformer. The end of my driveway is right at the main line. Am I screwing up every bodys AM radio in the area when running the lath? I really don't care, it was just a thought.
Re: Inverter
Re: Inverter
bernie feinerman
>Was your inverter still running while you went to the store?
If it was, then you may be wrecking AM reception in your immediate area.
Did you check if you were also messing up local FM reception?
A flourescent light, using an electronic ballast, in my basement interferes with some FM reception in my house. A similar fixture with a Magnetic ballast does not mess up reception.
Re: Inverter
Re: Inverter
Dave (PacNW)
>My Jet 1642 1 1/2VS transmits on the AM band the same way. I called JET and DUMB answers are still FREE! Other than that I love the lathe!
Dave (PacNW)
Re: Inverter
Dick Hines
Re: Inverter
Dick Hines
>It was. I had been turning most of the day. It does not consern me it it causes static on the AM band. It just got me to thinking.
I have a kid that spend most of the day rideing his dirt bike up and down the road. So if I am messing up wayones reception I hope it is his. If I find out it is I just may never cut my lathe off again.
Re: Inverter
Re: Inverter
Juergen
>Dick I posted the question about noise on the AM band when I operate my 3520B. It was suggested I turn on a battery operated AM radio to determine if the RF (Radio Frequency) is caused by the inverted or line noise. I even installed a new 220 outlet on a 70Amp sub-panel. just for the lathe. It turn out the AM radio screeched as much ad the radio running of AC.
Given my experiment your lathe's inverter is propagating all that RF. I didn't check how far it was radiating that's for another day. I sent an Email to Powermatic support. Anxiously awaiting a coherent response.
I wonder if they monitor Twitter? ;-))
Re: Inverter
Re: Inverter
Jim Sample------WebKitFormBoundary4+bM8dU5Q5ZoYOET
>When I first got my 3520B 3-4 years ago, I had the same question for PM. They gave me the name of a tech rep at Delta Electronics which I called to no help. They had a filter which was available on order (60-90 days) for several hundred $. I am getting by, my wife says the house AM is staticy when I am turning. The Jet/PM rep who I know says he knows nothing about all of this.
Jim Sample
