Calling all Studio Phot experts!
Steven Antonucci
steve antonucci
>I have been messing around with an idea that I found on the internet- making my own backdrop for shooting woodturnings! The backdrop is nothing more than contractor paper with black and white spray paint to make the fade (I used what I had on hand, which was satin finish).
If I can get decent results, I will make a larger one.
My questions:
When you set up your backdrop, how far from the back do you place the turning? where do you place the transition (Black to white)? What is the best position for lighting? The Camera?
Here is a quick test shot (hot spots off of the satin finish and all!)
steve
Re: Calling all Studio Phot experts!
Re: Background
Ron McKinley
>Someone posted a gradient background image that you can take to Kinkos and have it enlarged and printed on shiny paper. I haven't tried it since we don't have a Kinkos (maybe Staples can do the same thing and we do have Staples). It's 358kb and too large to post here but I can e-mail it to you to try if you like. Can't remember where I downloaded it, but then, I can't remember what I had for breakfast either! GRIN ....Ron
Re: Background
Ron McKinley
>I reduced it in size to about 38kb so you can see what it looks like. You can flip it upside down if desired...Ron
Steven Antonucci
The easy button...
steve antonucci
>Thanks-
I was getting better with the spray cans, but I like easy...
steve
>Steve The further you get the background back the easier it is to control the light hitting it. That being said the faded or graduated backgrounds are usually about54" long, some are 39" although I haven't ordered any for a long time.
To make your own I use the backside of vinyl flooring. Make sure the embossing doesn't show through. I spray the bottom 15 to 20" with primer gray and then I spray the rest with flat black. Start feathering the black spray where the background will still be flat. If you do that your camera will be low enough to help blend any odd spray marks. If you have an air brush you can do a really good job of feathering the spray. I'll have to look up my article in American Woodturner on shooting your work outdoors. I used a background exactly like this in the article. It was about 5 or more years back.
For small objects I just print a faded background on our epson printer. You can create the fade in photoshop really easy. Some printers leave lines that the camera can see but if you have a good one you can get away with it.
Re:Years ago I tried to make a gradient ....
Jamie Donaldson
>...with 4 shades of gray spray primer to black on a white vinyl window shade, but could never get a uniform shading without a visible pattern. I seldom use a gradient background, as they are overused in photography as a gimmick and substitute for poor lighting technique. A gradient background can be added to images with software when desired, but dark colored wood like finials disappear in the black on black without skillful use of lighting.
Steven Antonucci
Here's a slightly better one
steve antonucci
>I still need to pay attention to set-up (like getting my backdrop hung level!)
I think this one is a little bit better than the first one.
The vessel is 12" tall and hollowed to about 1/8"- Bug holes are great for judging thickness! Almost all of this vessel was hollowed with a hook tool, which I made in about 5 minutes out of a small scrap. The hooks cut so cleanly and quickly, I hollowed it in about 90 minutes, and then spent 3 days with a needle digging out frass and blowing the holes clean...
Steve
Re: Steve- the problems with direct.....
Jamie Donaldson
>....light are high contrast ratios, hard shadows, and lack of shadow details. That's why I'm a proponent of diffused lighting, because digital capture still lacks the exposure latitude we enjoyed with film, especially color negative film.Adding multiple lights only makes the problems worse with multiple highlights and shadows, so the KISS principle works well.
Re: And the background transition ....
Jamie Donaldson
>...from light to dark is too close to the subject, especially from this high camera angle.
