question on drying with ethanol
Bill Tindall, E.TN
>Long story, but I need to have some fundamental understanding of how this process works. Does anyone know, or if not, if I knew the benefits I could figure it out. Compared to simply air drying is it faster, result in less cracking/shrinkage, or what else?
Re: question on drying with ethanol
Ric Taylor
Ric Taylor
>Bill,
Look in the articles section for the article by Dave Smith. He developed the whole process.
Ric
>The basic theory is that the water goes into solution with the ethanol. The ethanol "draws out" the water from within the wood and displaces it to some degree.
When you remove your piece from the ethanol solution, the bound (and free) water has been partial replaced by the ethanol. As the ethanol has a vapor pressure of 40 mm hg at 19 C, it evaporates reasonably quickly. You don't have too much water left behind and it evaporates also. So figure you can get rid of a lot of water a bit faster.
I wonder if a large vacuum chamber would work or if it would be too fast and violent.
Dick Hines
Dick Hines
>I don't think ethanol is the sutff David ues. I know I don't use it unless denatured alcohol is the same thing. I have neen useing DNA for a few years and like the results I get. WhenI started useing it the price was $10.95 per gal. I got some last week and it is up to $15.95 per gal.
I think ethanol is poison.
nope... Re: question on drying with ethanol
GaryG in MD
>Dick, Every liquor store around is full of ethanol (=ethyl alcohol = "grain alcohol"). It's perfectly drinkable, in proper dilution, etc. ;-) It's methanol (methyl alcohol = "wood alcohol") that is poisonous. DNA is a "safe" alcohol that has been "denatured" (poisoned) by adding a percentage of methanol to it, so people won't drink it. ...Gary
GaryG in MD
>Bill,
You have been given good info here about looking up Dave Smith's approach and the basics of how the chemical works. OTOH, I believe there's more to it than that. Plunking your roughouts in DNA will make them crack like crazy if you don't follow the instructions! If you read Dave's publications carefully, you will see that he is ADAMANT about covering the outsides of the pieces with newspaper and leaving the insides open to air after the immersion. What this supposedly/apparently does is let the inside dry faster than the outside and create a compression force that holds the piece together (in effect, stops it from cracking). This is a good procedure to follow, whether or not you use alcohol. The alcohol just makes the drying process a little faster.
There may be a difference of opinion about whether the DNA process results in a lower percentage of cracking. I personally do not believe that it does -- assuming you handle the roughouts properly. The goal is to reduce the differential moisture content -- this can be done very quickly with DNA or slowly by maintaining a proper local environment (drying cabinet, brown paper bag, etc.) I will generally spray on a little shellac to slow the drying (also helps to see tool marks) and use brown paper bags. If I'm worried about a piece, I will wrap the outside in brown paper, but not the inside, before I put it into another brown paper bag. I've had excellent results with this procedure.
I tried DNA but didn't care for the logistics or expense. IMO, it's not necessary. I have plenty of roughouts backed up and have no need to rush one thru the pipeline.
If you do it, wear nitrile gloves -- the DNA will do the same thing to your skin that it does to the wood. ...Gary
Re: OT - sort of - Digital camera recommendation? *LINK*
Fred Holder--MW
>I had posted results on my alcohol drying on
the rec.crafts.woodturning
newsgroup, which triggered off
considerable discussion. I was severely
ridiculed by a few who assured
me that there was no way in
which this could work and that it
was a total farce.
As a result, I took another section
of Walnut Tree Root and
cut it in half. I turned two bowls
out of the two halves. Each had a
wall thickness of 1/2� and diameters
of less than 5�. I soaked one
in fresh denatured alcohol for two
hours and wrapped both in brown
grocery sack leaving the hollowed
part of the bowl open to the air.I was very surprised
at how similar the weight loss
ran. I�m presenting the results here
for your information:
Date Alcohol Soaked Unsoaked
5-17 225 grams 215 grams
5-18 200 grams 205 grams
5-19 165 grams 170 grams
5-20 150 grams 154 grams
5-21 125 grams 140 grams
5-22 115 grams 125 grams
5-23 105 grams 115 grams
5-24 100 grams 105 grams
5-25 100 grams 100 grams
5-26 95 grams 95 grams
In nine days the alcohol soaked
bowl lost 58 percent of its original
weight and the unsoaked bowl had
lost only 56 percent of its original
weight. The percentage of weight loss
each day was higher for the alcohol
soaked bowl than for the unsoaked
bowl. However, it was not as great
as I had expected.
In most of our previous tests
using alcohol, virtually all of them
had quit losing weight after seven
days, there was minimal warpage,
and no cracking in any of the pieces,
even madrone.
Dave Smith reports similar results,
but I don�t recall if he did any
side by side tests of the same wood
as I did in this second test. Dave said
with fresh alcohol, the wood was almost
always dry within seven days.
This has been our experience also.
In the first test presented here,
we used alcohol that had been used
several times in the past and was
likely fairly deluted with water from
the wood that had been soaked in it.
This last test used fresh alcohol and
the soak period was only two hours.
I hope this information will be
of use to some of our readers. I recommend
you give it a try on your
next wet turned piece. We used Denatured
Alcohol, so don�t drink the
stuff!!
This material was extracted from my article in the July 2006 issue of More Woodturning magazine. If any of you wish to see the entire article e-mail me and I'll send you a PDF of the story.
More Woodturning web site
Drying wood with alcohol *LINK*
Fred Holder--MW
>Hello all,
For some reason my post on this subject got posted under a title on Digital Cameras.
Think EtOH/water azeotrope
BOB HAINES
russ fairfield
>It has always been my experience that, if we were to take the same care in wrapping, inspecting, and weighing on a daily basis with every piece of wood, that we wouldn't need the alcohol. Given the same care and treatment, the only difference should be that the one soaked in the alcohol may dry at a faster rate.
Barry L Elder
>I quit using denatured alcohol because too many of our tropical woods cracked like crazy while soaking. Also, I didn't see any meaningful difference in drying time or warping in many woods that I use. Still have 2 or 3 gallons in a 5 gallon can waiting for someone to take.
The trick...
GaryG in MD
>with those tropical woods to reduce warpage and cracking is to BOIL them. Our friends Jim King and Steve Russell have discussed this procedure in great detail.
See, for example,
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=110857&v1=e2vrt43&v2=pneumatic+nailer&v4=belt+sander&v5=e2vrt43
and
http://www.woodturningvideosplus.com/boiling-green-wood.html
...Gary
Re: The trick...
Barry L Elder
>Yup! Boiling is probably the answer as soon as I can find a retired turkey fryer.
Ric Taylor
Ric Taylor
>All I can say is that I follow Dave Smith's instructions to the letter, except that I soak the rough-turned pieces for at least two weeks instead of the short time that Dave recommends. The only reason I do that is because it is usually at least two weeks between my turning sessions. I just can't get out to the garage any more frequently.
The results of my experience are that cracking and warping in various types of wood are reduced by about 80 percent.
Recently my friend and I cut book-matched platter blanks out of a large pecan crotch. They were identical, split apart face to face. I used the alcohol method on my rough-turned 16" blank and it only warped 1/8". The twin blank that my friend air-dried warped like a potato chip and was unusable.
Ric
good to know...
GaryG in MD
>I'm very glad to hear it. Boiling is easy in concept but logistically unappealing, unless you have a spare turkey roaster around. ...Gary
