question on turning small balls
Bill Tindall, E.TN
>I attended an Alan Batty demo and he mentioned in passing rapidly turning balls on the tops of chess pieces. He used what appeared to be a piece of pipe whose ID was the diameter of the ball to be ( for example 1/4"). I have a similar need. What I did not learn was how to sharpen the pipe and how to use it to make the ball. Does anyone know? Does anyone have Alan's email and I could ask him.
Re: question on turning small balls
Rick_Allen
>The pipe is smaller than the ball. Sharpen by grinding the outside (so the inner diameter remains unchanged). The pipe is soft steel and will dull quickly so sharpening needs to be done over and over and over. Use a light touch and you can get a fairly clean surface.
A washer can be used in place of a pipe. Rough turn the ball shape. flatten the washer on the side of a grinding wheel (this is soft steel so don't grind to long). Once the washer is flat you can "touch up" the "edge" by slideing the flat side of the washer on a piece of sandpaper.
In use the washer hole must be smaller than the "ball". Glide the hole of the washer over the spinning surface of the "ball". The high points will be cut off. Freshen the "cutting edge" often.
Keith Tompkins
Keith Tompkins
>HI Bill, I found a section of steel pipe, and ground and honed it all the way around. Holding up to your stock will form a perfect ball, in my case, 1/4 inch diameter. I left a small nub holding the ball to the stock which allowed me to sand it. Then, I parted off with a skew chisel. I drilled a hole in each ball while held in a tiny chuck with a carburetor jet drill.
GaryG in MD
>Bill,
You can see my writeup on this at
http://montgomerycountywoodturners.org/Documents/Tip12%20-%20Smal%20Wooden%20Balls.pdf
[FYI, my full list of tips is at http://montgomerycountywoodturners.org/Tips.aspx]
You will note that I reference a WC post by John K. Jordan.
For some reason, that link is no longer active, but, after an extensive search of the archives, I found the post at
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=178042&v1=e2vrt43&v2=carpentry&v4=cabinetry&v5=ly34ts5w
This is one of the reasons I love WC -- it's all here -- you just gotta know how to look.
...Gary
