Re: Jamieson signature grind? I haven't...
Lyle Jamieson
>Im Having a hellofatime, this is the third try at it. hope this one goes out there.
I can't get a photo to load I will have to get my talented wife to help me figure it out. It flashed a quick error note, I didn't have time to read, that said something about format. I have a PDF file of it on my desk top I was trying to use. You can see it on my web site www.lylejamieson.com. Look down toward the bottom of the store section.
The difference in my grind is twofold. First the side grind is tilted in slightly. This is not visible in the photo. The tilted in side grind gives a bigger, sweeter, easier to control bevel support all the way around the tip. This makes it easier to put the handle down in a pull cut mode AND still have the bevel support when you do the bottom of a bowl. This allows you to make a nice sweeping line with the bevel directing the cut instead of white knuckling it around the bowl shape. How?? To make the side angles tilt in, move the basket/pivot point away from the grinder. Try moving it 1/4 inch and see what a difference it makes. If you are happy with the tip angle you have it will be necessary to move the jig arm now because moving the basket will have changed your tip angle too.
Second, is the wing does not have a hump. The swept back wing from the tip to the heel of the wing is almost a straight line as seen in the side view photo. Assuming the grinding jig is set up correctly all you need to do to remove the hump is grind the high spot down. The advantage of removing the hump is huge. When you start a push cut the bevel is almost immediately supported. With the hump, the wood is being cut and the bevel is still out in mid air and you often will get a skating catch. When you grind the hump down the tip of the gouge will appear to be a little more pointier, and that's OK. All four cuts I describe in my Bowl Basics DVD are easier with the hump removed, push, pull, scrape, and sheer scrape.
