Tear out on box elder bowl *LINK*
George Taylor
George Taylor
>Working on a shallow box elder bowl (approx 9" width) and having a terrible time with tear out on the exterior. Before starting the interior, I would like to get the surface fairly smooth so I am not sanding forever. Is there a treatment to the affected areas that might stiffen up the fibers for one clean cut?
Thanks in advance.
George
http://www.galleryofwoodart.org/RestfulPlaces.html
Re: Tear out on box elder bowl *LINK*
George Taylor
Disregard the link
George Taylor
>Do not know why it was included.
GalenV in Iowa
>George:
Advice given to me as a newer turner is to use lacquer sanding sealer to stiffen the grain. Buy the time I learned this I had to coat and cut twice to get the torn grain cleaned up on box elder. Great wood but a lot of time for me to get it right.
Galen
Keith Tompkins
Keith Tompkins
>Hi George, Try this....using a very sharp spindle gouge, bevel rubbing, flute 90 degrees to the work surface cutting from the foot to the rim. Sometimes, working fromt the rim to the foot works, depending on the wood's grain. You didn't mention if the wood was punky.
George Taylor
George Taylor
>Not punky and fairly dry; had to fill some cracks with epoxy. Great flame though; hence the extra effort.
>The thinned lacquer should stiffen the fibers. You can also coat it with lacquer and then thin CA glue. Or just the CA by itself. May take a lot of it and it may show up in the finish if you don't cut/sand most of it away. Putting The lacquer on first may help with the matching, if you are using lacquer as a finish.
russ fairfield
>I 2nd what Keith said. I keep a couple of the Continental style spindle gouges around for this duty, but any gouge will work. You may have to grind it with a blunter bevel angle to get around the inside corner and across the bottom.
Stay on the bevel and it is an easy tool to use. There is a photo of one being used in the Grinds Library on this site. It's under "Odds and Ends" in the tool bar on the left side of this page.
Don Evans
>I've always had good luck using furniture wax, actually rather soft out of the can but this allows you to push it down between the fibers with a twisting motion. Pack it on don't be stingy with it. Let it dry overnight and harden.
Then turn it away with a shear cut, this should get it down to a manageable sanding point. Worse I've ever had with this was having to start with 80 grit but normally I can start sanding 180 grit.
Elder is worth the extra effort it takes.
Don
