Another Challenge
Another Challenge
Another Challenge
Tery Scott
>Siamese twins was turned from Red Mallee seemed a shame to cut it up into two bowls from Memory 1100 long
The set up on these pieces takes a long time ,you have to get the work balanced perfectly so it rotates without vibration
However I balance so much of my work it is like driving a car
I have since developed a new method of balancing by placing as big a fly wheel on the lathe as I can,makes the job of placing on counter weight allot easier
Re: Another Challenge
Some folks push the envelope. You threw it away.
adrien
Mike Nelson
>Love your work Tery, do you turn the first half then swap, adjust the ballance then the other half? But then when you flip it over how is it secured to the lathe? You should do a video, if you haven't already. Mike
Tery Scott
>Love your work Tery, do you turn the first half then swap, adjust the ballance then the other half? Yes
But then when you flip it over how is it secured to the lathe? By a spigot or any way I can hold it on I pride myself in that I don't think I have ever been stumped as to how to hold a piece on the lathe.I enjoy the planing process and the more difficult the more I enjoy
Probably scare the S*&^7 out of myself seeing what i do on screen l.o.l
