A55 Smoothing Plane
Traffic light front
Traffic light front
Traffic light front
Tery Scott
>front View starting the bowls the carving was done with a kingarthur merlin bit
those tow balls are know permanent items in my turning kit The Mdf has been cut around the chuck and glued onto the macrocarpa with holt melt glue
I could have made this 100mm longer but I would have had to chock the lathe off the floor as this just clears the floor by 50mm
Re: Traffic light front
Re: Yes Terry, you are NUTS!!! I can't....
Jamie Donaldson
>...believe you trust hot melt glue for anything, let alone a spinning prop of this size!
Mike Stafford
Mike Stafford
>I put on my helmet, faceshield and suit of armor and then hid in the closet after seeing this picture. Am I chicken?
Cluck, cluck, cluck!
Terry, the sky is falling....
Dick Hines
Dick Hines
>Looks like a good way to loose an arm to me, Can't wait to see the finished piece.
Arm? How About A Head?
Barry Turner
Mike, I hope it was a good closet......
>I don't think sheetrock would help much. Maybe a brick out house far far away, in another galaxy. I'm with you, I don't trust hot glue for anything except to burn me. He's not talking about hide glue is he?
Amazing work. I just don't have the nerve. I am stunned at the scale of these pieces. 1100mm is over 42".
Steven Antonucci
How to make sure nobody "plagiarizes" your work!
steve antonucci
>Anyone that tries, dies...
S
P.S. Love it, and the scale is somewhat unimportant...but wicked cool!
Re: Mike, I hope it was a good closet......
Tery Scott
>The process of applying hot melt glue that i use is
apply to the fly wheel ,wedges and backing board a Heep of glue ,I use 2 glue guns at a time .with a heat gun preheat the service so it is warm
By the time you have applied enough the glue will be cold so with the aid of a heat gun or gas torch melt the glue again in one go by running around in a circular motion set the work on the fly wheel first preheating the wood to be turned .Finally leveling and positioning can be done with wedges or packers
Additional support can be given by using webbing .Trailer tie downs are ideal
Usually the areas glued are turned off at a latter date but by soaking in Mineral turpentine the glue debounds
Cheers
YIKES! Not for me. You have fun with that.
Mike Foster
Randy
>I've used hot glue to attach square blocking to antler while cutting it on the bandsaw. Haven't found any antler as big as this though.
