Re: Thin parting tool advice
Dave Peebles Lyons, Ohio!
>Hi Bill,
I have one of the Sorby's too, and the instructions point to using it flute down. Using it this way will make a mess of the tool rest. It sits in the rack most of the time, but it does cut very cleanly.
Here is the info similar to what I got with mine... we may be talking about different tools entirely. :)
Fluted Parting Tools: An even more recent innovation is the fluted parting tool and versions of this are produced by both Henry Taylor and Robert Sorby. The advantages to both designs is that the wood fibres
Standard fluted parting tool - similar for both Taylor & Sorby Designs.
bordering the cut line are severed cleanly before the main
2mm parting tool by Robert Sorby
part of the blade clears out the bulk of the timber from the kerf. This results in a very clean cut surface which normally does not need subsequent cleaning up.
The Taylor model HS2 and Sorby 832H - 3/16 are similar in design with a flute running the length of the bottom edge. Both are used with the flute down onto the toolrest (this can cause damage to the toolrest surface, which should occasionally be dressed with a file .) These should be sharpened by grinding the bevel (front) face only. The tapered profile serves, like the diamond-section tools, to reduce friction in the cut.
Dave
