REAL MILK PAINT
Red Square- start of a new series.....
JamieD
>...of dyed turnings, many of which will be squares. I'm exploring the use of dye materials which are more permanent(light safe) than anilines, which are notorious for fading. The metal acid and pigment dyes are seldom known in the turning field, and introduced to me by Gary Sanders during a class at the Folk School this fall.
Re: Red Square- start of a new series.....
Katherine Kowalski
Katherine Kowalski
>Jamie, lovely piece -- the dye really allows the figure to stand out!
Transtint makes a good set of metal acid dyes which are very lightfast. I'm glad that the major stores like Woodcraft/Rockler/online have been carrying these -- makes it easier for us to shop!
Re:Katherine- this piece has 3 TransTint..........
Jamie Donaldson
>...colors in layers, starting with black,red, and a light wash of blue, followed by a thin application of pearl/blue interference made by Golden. I'm mixing the dyes with alcohol rather than H2O to speed up the drying time, and that changes the way colors blend rather than layering.
Dennis Yoder
>Hi Jamie, The dyes really make the rays pop! What are you using for a top coat? Dennis Y
Re: The finish is Krylon Triple Thick....
Jamie Donaldson
>...spray lacquer from a rattle can, sanded to 3K with 3M Trizact foamback pads, then hand polished with Nufinish car polish.
Dan Oliphant
>Jamie,
I'm a little confused by your layering comment. Are you using alcohol based dye because it will layer without blending, or because it blends with the previous color layer?
Re:Dan- the TransTint dyes can be ....
Jamie Donaldson
>...diluted for use with water or alcohol, or a 50/50 mix of both to reduce grain raising prevelant with the H2O mix. I'm using alcohol to reduce drying time and grain raising, and when dry the colors don't blend as much as they do when the previous color layer is still wet. When the wet colors are rubbed into the wood surface they are more transparent, whereas airbrushing would lay down a surface coat that would be more intense.
Mike Stafford
Mike Stafford
>Mr. D., this is quite a lovely piece you have created. The color is rich and deep and the finish is exquisite. Work like this would be snapped up in a minute if folks were given the opportunity.
Very nicely done!
Barry L Elder
>Jamie, when you do these, do you have a set time method for each color or do you use the "eyeball" method. This piece is really outstanding!
Re: Barry- it's easy to see when the........
Jamie Donaldson
>..previously applied dye/alcohol mix is dry on the wood, and then ready to apply a new color. If I want to blend multiple colors, then it is time to apply back to back, like blending red and blue yields purple. Knowing how colors react with a color wheel as reference is a great help, but there are still occasional surprises!
Cyril Griesbach
>Jamie, the piece is beautiful and the information you've given in the responses is a great help. Thanks much.
I can see a rainbow of colors emerging
Mike Foster
>Looks like the start of a great series. I haven't done any colored pieces since the week at J.C. Campbell, but have been collecting some nice inks and paints to try once I get a chance. Lately my time has been spent with piece that I hope to enter in the AAW Maple challenge. Nice work Jamie.
Mike
