Re: RF Noise withe 3520 Lathes
Ralph
>Bob, that only works if the AM radio in question has a three-prong (mine doesn't) and the RFI is only carried on the ground and not the neutral. Since most breaker panels are wired with the ground and neutral bonded together... I doubt this would work
Not having a PM3520, I can't answer the original question. But...
If the RFI is "broadcast" by the lathe, the issue is the lathe is not shielded properly. The test for this is to use a battery operated radio or the car radio. If this is indeed the RFI source, the only solution would be to find a way to shield the lathe.
If the RFI is carried on the power-lines, you need get a power-line filter that you can plug the lathe into, then into the main-power. Since I think this lathe is only wired for 220, this filter would have to be a 220V (rare).
I can say that with the DVR-XP, the primary mode appears to be broadcast (ie it interferes with battery powered radios), which means that is has to be shielded better.
The problem arises because the FCC (and others) do not consider power-tools to be "Consumer Items) and thus they do not have to meet consumer RFI standards (like computers have to)
