PM 3520 ?
PM 3520 ?
PM 3520 ?
Paul Woelper
>Today(thanksgiving)I was turning on my new powermatic when I noticed a clicking sound. It seems to be coming from the spindle but keeps time with the digital rpm reader. has anybody come across this problem? Thanks for your help Paul
Re: PM 3520 ?
Re: PM 3520 ?
Gil Jones...GA
>Could be several things that cause that sound.
With the lathe power cord unplugged!!
Check that your drive belt is running true in relation to the pulleys, and that both pulleys are truly inline with each other.
Also, while you are playing "inside the headstock�, tighten the setscrews on the upper and lower pulleys.
On mine, sometimes, the belt tension (tight or loose) can cause a sound to be emitted from the drive area. More or less tension on the belt can fix that one, but I would bet on the pulley setscrews being loose, or at least not tight enough.
Re: PM 3520 ?
Dick Hines
Re: PM 3520 ?
Dick Hines
>Check the spindle lock. the collar on mine works loose sometimes. If you can get the spindle lock button out you can reach through the hole with an allen wrench.
Re: PM 3520 ?
Problem with set screws
Aage Rendalen------WebKitFormBoundary4Q2A+Myz6C6Lp
>Apparently the 2035B has a problem with loose set-screws. I had the same problem as you and once I had tightened the set-screws it went away. Get yourself a set of long t-handle allen wrenches and you'll have no problem reaching the screws.
