Dirty Lathe
Dennis in Southern Oregon
>Does anyone know an effective way to remove accumulated dried hardwood sap from a lathe? I would rather not remove the paint in the process!
Dennis
Dirty Lathe
Dennis
Badge
Dave Peebles Lyons, Ohio!
>Hi Dennis,
I do not know for sure. But my lathe wears it as a badge of honor. :)
I guess it would depend on the finish the lathe maker used. It might be best to check with them for a solution.
Good luck,
Dave
Re: Dirty Lathe
Jim Sebring
>You might try one of the citrus-based spray cleaners available from your local grocery store. I'd try it in an inconspicuous area first.
You might also try Murphy's Oil Soap (also available from the grocery store). I don't think there's any chance of it attacking paint. I've used it to clean up antique hand planes in my collection without it causing any damage to either the Japanned (black varnish) finish or patina on the metal parts.
I usually use mineral spirits to get the shipping grease off new tools from the Far East.
Most of the "hot" solvents like MEK, acetone and lacquer thinner will definitely do a trick on some paints.
Re: Dirty Lathe
don lewonczyk
>You might want to try the bug and tar removers that you use on cars. Try a small area on the lathe out of the way. If it don't hurt car finishes it should't hurt the lathe paint, but follow the directions. DonL
Re: Dirty Lathe
Ken Oakley-Sunny St. Cloud,Fla
>Simple Green removes all the buildup on my sawblades and I soak my sanding belts in it to remove the buildup. Denatured alcohol works for me on the sap from the trees in my yard that drip on my pickup, and an August sun here in Central Florida bakes that prettu good.
Agree: a clean lathe is an unused lathe!
steve antonucci
Re: Dirty Lathe
Dick Hines
>My PM looks pertty bad but the ways are clean and that is all that matters. I spray WD40 on the ways when i start a session and again when I finish. Wipe them down with a paper towel and the old PM is good to go.
Not dirt, well seasoned.
David Belser
>It's like a well seasoned cast iron pan.
Periodically wax the ways and where the banjo and tail stock ride on the ways. If you have cast iron with an inside thread (ie. the tool rest lock) hit it with a little oil on occasion.
Re: Dirty Lathe
Barry Turner
>I'd probably try plain old soap and water before moving to solvents. This seems to work pretty well on tree sap on my vehicles. If this doesn't work, I'd probably try mineral spirits next.
Re: Dirty Lathe
Keith Tompkins
>I'm the odd man out...my lathe still looks almost new. I work hard to keep it that way. It's got a couple of scratches, and the powder coat is softening on the tailstock where oil from the bed contacts it.
Re: Agree: a clean lathe is an unused lathe!
Doug Thompson near Cleveland
>I can't wait to get this dirty!
>Doug,
Why is there a chuck in that operating room. :)
Get busy buddy,
Dave
John Jordan
>Are you getting close? I know you'll be glad to get it going. I need to get you to make some small parts we talked about.
John
Re: Dirty Lathe
John Jordan
>I'm with you Dennis. I even spray a little paint from time to time. Well maintained tools do good work. :)
Soap and hot water are the first "solvent" to try as Barry said.
John
Re: Dirty Lathe
Charles Watson------WebKitFormBoundary+ATeQdvhmFc4
>I try to keep my lathes as clean as possible, even covering to some degree when turning fresh cut wood. My original PM 3520 is about due a little touch paint.
Re: Dirty Lathe
>Clean lathe. My lathe is also clean. It has some chips in the paint due to attaching tools to the headstock with magnets but I clean the bed regularly and wipe up any residue from glue or finish immediately. Since I don't actually finish on the lathe other than applying some thinned lacquer there's very little to actually clean up. The worse problems is keeping the wet wood spray off other equipment in the shop.
Yes Steve but...
Steve Kubien
>...and clean, unused lathe could also mean a new lathe. Let's have a big round of applause for new lathes!!!!! Hmmm, wish I had one to gloat about.
Re: Dirty Lathe
>Thanks for the inputs folks. Sorry for the delay in responding, but I had an unscheduled computer maintenance event last week :(. It looks like the vote is about two to one in favor of wearing the dirt as a badge of honor. The problem is that the accumulation of sap occurred right after I got the big white beast a few years ago during a frenzy of roughing out a bunch of madrone bowls. I did not realize that there was a potential problem and took no steps to protect the lathe. Since then, I have tried every solvent in the shop short of paint remover and can't make a dent in the original deposit of yellow-brown epoxy-like stuff. Too bad I cant' find a way to apply this stuff to salad bowls and other kitchen wear; it would last forever!
Dennis
Try hot air and scraper.
John Cotten
>Dennis, try heating the sap with a hot air gun similar to one used for removing paint from a house. It should soften up the sap. Then use a hard plastic scraper to remove the sap. It should work. All natural saps I have worked with have softened when heat is applied.
The thin residual amount should then come off with a good solvent and a heavy scotch brite pad.
Good luck.
