Re: hollowing
eliot d
>Don't use a spindle gauge. It could break. They're for spindles. I wouldn't bother with a termite tool or ring tool , either. Just use a bowl gauge or small scraper like a Jordan tool or any of the others made for hollowing. The surface you get will be a bit rough; so sand it. You can save yourself some time and effort by drilling out a significant portion with a large bit first. For small open hollow forms I , personally, often use a so-called box tool for the final hollowing. It's basically just a heavy scraping tool with a rounded corner that's offset a bit from 90 degrees to give a little clearance from the side of the form. Remember, to get thin walls, you must turn a few centimeters thin near the rim and not go back. Then turn the next few centimeters thin, further in, toward the headstock; and , again don't go back out toward the rim. The mistake that people often make is to turn the whole goblet sort of thin and then start over again to make it thinner. That won't work; the goblet will start to vibrate and possibly break up.
