Sanding epoxy
Sanding epoxy
Sanding epoxy
Mike Foster
>I have a rather large area of a turning that I need to fill with some epoxy or filler but need to be able to sand it smooth with the wood around it and get a smooth surface on it after turning and sanding. I have some old 3 Systems T88 that I already used in the area, but found that the epoxy was not hard enough when set and tended to smear when sanding. I was pretty sure epoxy has a unlimited shelf life, but perhaps not. I've had this batch for a long time. I don't think it was a function of too much heat as I was sanding very slow with little pressure. Does anyone have a product that may work better for me? I know there are turners that fill in large voids with colored epoxy with outstanding results.
Re: Sanding epoxy
Re: Sanding epoxy
Ray
>Most epoxy has no limitations on shelf life, but you may need to heat it if it is crystalized. Epoxy as mixed is to hard and brittle to be of much use(IMHO). Mix some micro balloons or West Systems Microlight 410 until you have a rather stiff mix. It will sand out nicely.
Ray
Re: Sanding epoxy
Re: Sanding epoxy
>Mike I have used that epoxy as well as System 3 mirror coat, West Systems epoxy and the cheap ole 5 minute hardware store variety. Only once have I had it stay soft and I couldn't put my hand on why. I level it with the gouge or carving tools and then use shear scraping to get as smooth as I can before sanding. However in the old days I would usually just start sanding at 80 or 100. Other than clogged discs I don't remember a problem. I know that's not much help now. Try sanding or carving it below level and refill with some new stuff.
Re: Sanding epoxy
Re: Sanding epoxy
Mike Foster
>Ray,
I've actually de-crystallized my epoxy a couple of times. I did lose a cap off of one of the parts, and it has been exposed to air for quite a while. Not sure if that would change the chemistry. I have some additive for making a thicker epoxy that System 3 makes, probably similar to the microlite you mentioned. I didn't think of trying that, but it is on the to do list for tonight. Any thoughts on keeping air bubbles out of the mix.
Re: Sanding epoxy
Re: Sanding epoxy
Mike Foster
>I'm going to do just that tonight.
Mike
Re: Sanding epoxy
Re: Sanding epoxy
Ray
>According to System three crystallization does not change the chemistry and no harm is done. As to air bubbles, that remains a problem and gets worse as you add filler to make it thicker. I add filler and turn it out on a mixing board and mix with an offset palette knife. Keep pushing it into the board as you mix and that will help minimize air bubbles but I haven't found a way to completely eliminate them yet, still experimenting though. A side benefit to mixing on a board is it lengthens the working time by increasing the surface area, adding a fan to help keep the mix cool will add additional working time.
Ray
Re: Sanding epoxy
Temperature
Jorge Castaneda~Downeast Maine
>Mike,
I use Gudgeon Bros epoxy and sometimes mix thickeners, my favorite is colloidal silica. Keep in mind that all additives will change the color of the epoxy, if it must be clear, then heat up the shop high, 75F to 80F and then mix your epoxy very carefully and apply. The warm epoxy will set faster, but it will let go of bubbles a lot easier, you could also use vacuum.
A sharp tool with small bite and ribbons will come out. I sand to 600 or 800 with wet dry sand paper and oil.
Jorge
Re: Sanding epoxy
Re: Sanding epoxy
Fog Tanner
>Mike,
I have had epoxy go bad. I tried using some that was around 10 years old and it would either not set or not come out of the bottle. In the case of the epoxy that didn't set, I had to sand it off and start over with new epoxy. I have also had new 5 minute that always stayed slightly pliable, which was OK for that application. In the case of the glue that won't come out of the bottle, I am still working on that.
Most of the epoxies you will get will set in a few hours past their working time. But, they take a full seven days to cure - set and cure are different. For the cosmetic filling applications I typically let them set for 36 hours if I am going to machine the surface to keep from pulling the epoxy out. If I am just sanding, overnight is normally good enough. If you are using it as a gap filling cosmetic, it is stronger and more sandable with a filler. I use coffee and tint the epoxy black. When sanded you can't tell its an epoxy filler.
If I am looking for strength in the glue, I wait a week before stressing it. You can still move the glue joint after 24 hours if it is stressed, can handle it at 36 as long as you don't stress it - and as good as it gets after seven days. These are glue ups where I am asking a lot of the glue and materials and not typically what you would find in a bowl.
There are of course a whole number of specialty epoxies which have different working, set and cure times. Some only cure at high heat, which would leave you with a piece of charcole with an epoxy filling. Would make for an interesting art piece, but not something you could put your M&Ms in..Others can be poured in a mold and when cured can be turned into a bowl capable of withstanding a hockey puck at full speed. For my use, it is making a 200mph R/C raceplane - but a small bowl is a thought. None of these are what you would find at the box stores or marine supply places, but can be had from foundry supply or pattern makers supply houses.
Fog
