Re: Question on Crotch Grain/Hollow forms
Barbara Gill, Remlik VA
>All pieces of wood like this have two piths to consider. It has been my experience that most walnut is pretty stable so the pith inclusion if necessary might not be an issue. How much pith free figured wood you will have depends upon how large the log is.
I would turn the typical end grain hollow form to maximize the figure. To get the blank I would probably try to saw the crotch through both piths and then cut the blank based on the figure. As you get out toward the bark, the figure will disappear.
The other possibility with a crotch is to saw it 90 degrees to the way mentioned above. This way instead of getting the typical flame figure it will resemble a sunburst.
Because of my sawing experience, I would be more likely to use the crotch figure for plates than hollow forms as it is easier to retain the figure.
Either way, once you decide how to make that initial cut, it will be easier to make a decision as you will be able to see the figure.
I hope I haven't confused you.
