>I recently purchased a vacuum pump. I am curious. Can I use traditional clear hose to go from pump to filter to relief valve to lathe? Or should I use vacuum hose if there is such a thing. I am concerned about the hose collapsing on itself. Any suggestions would be helpful. As I am hoping to put this together soon.
>Derek, your concern that the hose will collapse is warranted. Most people use reinforced plastic hose that is 3/8" inside diameter. This hose is clear so you can see the web of reinforcing material inside. It is available at home centers and hardware stores.
Yes, there is vacuum hose available but you don't need it for the level of vacuum used in these systems.
Incidentally, the hose barbs you will need are 1/4 NPT, 3/8 Hose.
>Doc is right. I installed clear hose on my system and it's been working for the last 3 years but you can see that it is trying to collapse and tries to kink. I bought the web reinforced tubing but simply haven't taken the time to install it. I think about it every time I need the vacuum system but by the time I finish using it I run to something else and still don't replace the hose. Life is too hectic.
As the others have said the thick wall is a must. Don't worry about the webbing though as it only works in tension and so increases the positive pressure rating of the hose. It will not affect it's ability to work in a vacuum application.
>I use the coiled compressed air hose and quick connects. I have never had an issue with this hose or setup. The hose gets double duty for compressed air and for the vacuum chuck application.
