Grex ROS
Grex ROS
Grex ROS
Randy Johnson Connersville IN
>When my trusty old Milwaukee right angle drill bit the dust a week or so ago I decided to replace it with a Grex random orbit sander. Previous threads on this board convinced me that, while my compressor is smaller than the Packard catalog says it needs to be, it would do the job. The compressor has to run continuously but that isn�t a problem.
What IS a problem is that the sander quits rotating with all but the very lightest pressure. Without the air hose attached I can spin the disk freely without the parts of the sander driven by the air moving at all. Looking at the exploded drawing, it looks like the part the disk holder slides into is retained by a split ring. This would explain why the part spins so freely, but at the same time it means that there is nothing to make it turn when pressure is applied. It�s like expecting a drill bit to bore through ten year old hedge without the chuck being tightened first.
This is the first air tool I have ever owned and I�m hoping I�m missing something that should be obvious. Is the condition I�ve described normal? I hope not, because as it is I could sand faster by hand. If there is any complaint I have with this tool it is that the �manual� that comes with it gives so little information that it is all but worthless.
Re: Grex ROS
Re: Grex ROS
Rick_Allen
>You are expecting a lot out of this tool and more out of your compressor. Most of the sanding effort comes from the random orbit and mot from the spinning. Depending on where you got your GREX from the air consumption could have been reduced by limiting the speed of the tool. The fact that the compressor run all the time tells me that the tool is not getting the desired PSI.
PSI + consumption = power for an air tool.
Most air compressors are designed for a 50% duty cycle. If the compressor is running continuously you are using the air compressor at 100% duty cycle. The compressor will have a very short life if you continue this abuse. The good news is that you will soon need a new compressor, so you can get one that is large enough for the job (think 60 gallon, 2 stage, 5 horsepower). Combine a big air compressor with that GREX and you will be well on your way to efficient sanding. BTW you need a way to keep the exhaust off your turning. Rear exhaust along with a long exhaust sleeve will help to keep the exhaust (and the oil in the exhaust) off of the turning you are sanding. You likely need an inline oiler so the GREX has a long and happy life.
Re: Grex ROS
Re: Grex ROS
Bill Grumbine (Kutztown PA)
>Randy, I bought one of these about four or five years ago, thinking the very same thing, and went through the same disappointment you are experiencing right now. However, I still had my trusty drill named Sioux. The bad news is, the Grex is lousy for stock removal. The good news is, it excels at that final finish for removing sanding scratches - or in reality, making them harder to see.
Re: Grex ROS
Re: Grex ROS, it almost sounds like...
bob elliott
>...you are using the Grex while the piece is spinning on the lathe?
A random orbital sander will NOT work on a spinning piece, the piece has to be stationary, as if it were a board resting on your workbench. The action of the piece spinning puts the stop to the random orbital action.
Re: Grex ROS
Randy Johnson
>I did occasionally use the old Milwaukee while the lathe was turning at very low rpm but all I�ve used the Grex for so far is natural edge bowls and, needless to say, the lathe isn�t turning while I sand those.
It looks like I may have to go with Bill�s solution and return to an electric sander for the time being. I�m sure that my requirement for stock removal, i.e. tool marks, is a great deal more than his. This is particularly true on natural edge bowls and anything made from walnut.
A bigger air compressor is on tap for the coming year.
Not that I post all that often anyway, but this might be my last one for a while. I�m posting this from my sister�s computer because both of the ones I normally have access to have developed some serious problems and will be heading to the shop as soon as I can get time to take them there.
Re: Grex ROS
Re: Grex ROS
Ron McKinley
>I had the same problem with my Grex and a friend told me to tape a piece of wood to the under side of the trigger so you couldn't run it at top speed and that worked. Before, I could get 20 to 30 seconds of sanding before the air pressure got too low in my 30 gal. compressor. Now I can sand more than a minute before I have to wait for the pressure to build back up. Really, my Harbor Freight electric angle sander works a lot better and I get continuous sanding. Anybody want to buy a like new Grex ROS? ......Ron
Re: Grex ROS
Re: Grex ROS
Donna Banfield
>I have used the Grex ROS and the Sioux ROS for several years. Like Bill Grumbine said, these air sanders are not for removal of stock or tool marks. Use your corded electric drill for the lower grits, and then move to the air sanders for your higher grits. I typically move to ROS at 220.
These sanders are also best used with the lathe off. If you try to use them with the lathe running, you will get a Spirograph pattern. This will be most noticeable on the bottom of bowls, or the flat surface of large plates/platters. Naturally, keeping the lathe off will take longer to sand the entire surface because YOU need to do the moving.
So, you might wonder, why anyone would use the air sanders, if they take longer? Simple -- you get a superior finish.
Re: Grex ROS
Re: Wrong Tool For Job ? ? ?
Barry Turner
>I think you may have picked the wrong tool for the job at hand. From what I understand, the Grex random orbit sander is more of a finishing sander. My sander of choice is an old Panasonic 9.6 volt cordless drill with a 2" hook & loop foam pad. It work great, even when I have to start with 60 or 80 grit disks. I sand at about 1500 rpm on the drill with the lathe running at a couple of hundred rpm in the opposite direction to the drill. Works great. Get yourself a cordless drill. Note: Panasonic drill do not have vents for cooling, which also prevents sanding dust from entering the drill and sapping the working life. Mine has been used for sanding bowls for 10+ years and is still going strong.
