I posted recently about loaning out my McNaughton
>Coring system. When it came back it was thoroughly mangled. My Friend ground the cutters on the top surface rather than the cutting edge and completely removed the hardened steel form one and most of it from the other two.
Someone suggested contacting Mike Hunter about putting new cutting tips on them. To make the story shorter, I tried Mike"s modification out today. I have only use the smaller of the blades, but I have to say it makes an amazing difference. If you have any inclination to do this, go for it. Thanks Mike.
A couple of questions. When the system came back, it had been reassembled in new and strange ways. There is a piece of pipe on one side of the restraining bar. Apparently he thought the bar should be fatter. There is tape around the bar and pipe or conduit over the tape. Anybody got any idea how to remove the Pipe? Does the vertical restraining pin come out?
As a matter of curiosity, there are two set screws in the bottom that are threaded up into the vertical "riser", but the riser is heavily welded to the horizontal piece. What are the set screws for? Did they just hold the pieces until it was welded?
And does anybody know what the set screws in the handle are? One of them is missing.
