>I need to glue a bottom segment onto a large (15") walnut bowl. I am in a bit of a hurry. How quickly could I put the bowl back on the lathe and start turning it again? Would you wait an hour or what? So I have to wait the mystical "over night"? (What happens to glue during the night anyway?)
>Depends on how much glue surface you have and how tight the joint is. If it's fairly light weight bowl and you have a large flat surface to glue to then it should be dry in an hour.
However I wouldn't rush it. The longer you wait the safer it will be. Don't ruin a project by trying to rush it. I've turned spindle glue ups in an hour and when I used to do segmented bowls a layer at a time I would only wait 30 minutes between each layer.
The bad thing is if for some reason the glue joint isn't really tight or maybe it's too cold wherever you are then you could ruin your project.
>Darned if I would turn it after an hour. It might look dry around the joint where you can see, but odds are it's not cured inside where it's not exposed to air. What does the bottle of glue say?
>I'm a Titebond original fan and have no experience with Titebond III. With that said, I would not turn ANYTHING that had been glued up for only an hour. I don't think "overnight" is mythical at all. It just provides a margin of safety. In some cases, "overnight" might even be pushing it. Think about it. The moisture in the glue line has to go somewhere.
