Looking for ideas...
GaryG in MD
>I've got a 6 1/2" diameter burl bowl, simple shape, with a 3/4" NE rim full of the typical spikes (bark gone). I left the rim that thick on purpose to highlight the natural lumps and bumps. The wood is either buckeye or maple with lots of dark areas (no photo available right now) and some curl, chatoyance, birds eye, etc. Nice wood. I plan to finish it with Watco oil to really pop all these features, and I plan to bring both the inside and outside to a satin-level shiny finish. No color currently planned. My problem is that I can't decide how to deal with that raw rim that I'm trying to highlight. I've rejected anything like black or gold -- too unnatural. So what choices do I have? I can just leave it alone... I can texture it with a brass brush, or not. I can get finish on the rim, or not. What have I missed? Based on your personal experience, what do you recommend? I'm interested to hear from those of you who have actually faced this situation, made a decision, executed an approach, and achieved the results, for better or worse. Thanks, Gary
Re: Looking for ideas...
Barbara Gill, Remlik VA
>Gary, I have always just used oil on the edge of the natural edge bowls. I am careful to only put one coat of oil on the edge and get rid of the extra to avoid an uneven finish. Needless to say I don't buff the edge. :-)
Cyril Griesbach
>I'm with Barb on this as well.
Tery Scott
>Good morning Id suggest a light burn with a gas torch and then wire brush by hand This has the effect of creating shadows
more pieces like this can be seen on my web site www.timberly.co.nz under burls
Keith Tompkins
Keith Tompkins
>woodburned texture?
Barbara, John, Cyril,...
GaryG in MD
>Thanks for your thoughts. That certainly sounds like the safest and most traditional approach -- that was/is my backup position if no "magic" ideas appear. ...Gary
GaryG in MD
>Hi Terry, Nice to hear from you. I certainly value your input. I'm interested to hear that the item you pictured has been burned -- I wouldn't have guessed it. Are you talking about the subtle black line around the outside of the bead or the whole surface? In my case, I don't have a flat surface -- just the 3/4"-wide, debarked, uneven rim of the burl bowl with lots of sharp points sticking up. I'm afraid to use a torch because the tiny, sharp points would burn off first -- they are what I'm trying to highlight and preserve. I'm afraid that using a microtorch between the points would end up looking somewhat haphazard. Perhaps I'm not understanding your response. Thanks, Gary
