Emir's Eccentric Turning Method
charlie belden
>There's a turner living primarily in Italy, of Persian descent, who travels the world 6 to 8 months of the year on a quest to turn as many kinds of wood in his lifetime as he can. And in the process, he shares what he knows about wood and turning, and learns from other turners, distributing what he's learned to other turners he stays with during his journey.
During his stay in Australia (or it could be New Zealand), he got a chuck maker to machine him up a set of small stepped "pin" jaws for turning rings. So - you may be seeing them on the market at some point in the future.
Anyway, Emir demonstrated an interesting method for eccentric turning using a four jaw chuck - and a stepped tenon which some here may be interested in trying. (see attached illustration)
*****CAUTION*****CAUTION*****CAUTION
RISK OF INJURY -RISK OF INJURY -RISK OF INJURY
This IS NOT THE MOST SECURE HOLDING METHOD and is not suited to aggressive turners - LOTS OF LIGHT CUTS reduce - but may not eliminate - the turning flying off into space while being worked on.
Re: Emir's Eccentric Turning Method
Eduardo Sarmiento
Eduardo Sarmiento
>Hi Charlie, the method is used almost in many places by turners in europe and the us too,check this out,he is from spain and has some really nice videos about eccentric turning and ornamental turnings
http://www.youtube.com/watch?v=GHFmkMMljHI
Re: Emir's Eccentric Turning Method *LINK*
Ed Davidson
>The same offset process is demonstrated in this how-to video I shot a few months ago - link below. Think I first saw this being done by David Nittmann several years ago at a Utah symposium.
Offset Handle Turning
Again - Nothing New Under The Sun
charlie belden
>As is so often the case - there's very little truly new under the sun.
Thanks for the links to the videos
Re: Again - Nothing New Under The Sun
>Wonder if you could mis-match the jaws. Just substitute two smaller jaws for two larger jaws and make the chuck eccentric?
Don Orr
>You can do basically the same thing with the serrated Oneway jaws by tilting the wood out of the jaws enough to seat in the next indentaion made by the serrations of one of the jaws. It holds really well and no steps or special jaws required. Still need to use light cuts and great care.
Re: Again - Nothing New Under The Sun *LINK*
charlie belden
Unless they had the same inner diameter, you'd effectively be gripping with just the two opposing smaller jaws since they'd grip the tenon before the larger jaws would reach the tenon.
Another way of TILTING the axis, as opposed to offsetting the axis parallel to the lathe's axis, is to turn 3/4 of a ball on the chuck end of the blank. You can now use all four chuck jaws to grip the "ball" end - keeping the chuck end center about the same but effectively moving the other end's center anywhere within about a 30 degree cone. (see attached link)
You CAN shift the center of the turning parallel to, but not on, the lathe's axis using just two opposing jaws on a chuck
ball in chuck eccentric turning idea
Re: Remember the Safety Rules
russ fairfield
>Rule 10 on the AAW website says - "Make sure the blank is securely fastened."
While all of these various schemes will work, none of them can be described as being "securely fastened". Use them at your own risk. Take very light cuts, and always be ready to duck.
