live center unthreading
bill sams
>While sanding today with the lathe running in reverse, the live center that came with my pm3520A threaded itself out of itself. Has anyone had this happen before?
I let it cool down, oiled, re-inserted the bearings, and the threaded section back in the live center housing, and tightened.
Started turning again but sanding in the forward running position, all seems to be ok
Just wondering is this has happened to anyone else.
Thanks
Re: live center unthreading
Gil Jones...GA
>No trouble with mine (B-model), but I reckon if a bearing(s) started to lock-up it could unthread itself. Then you might also expect it to get hot, make noise, or freeze up when in forward too, if it was a bad bearing.
Be interesting to know what you discover.
Re:This has occasionally happened....
Jamie Donaldson
>....with the "copies" of the original Oneway live centers. Most have a black bearing housing cover, but later were chrome just like the Oneways, and the snake-eye spanner retaining ring(brass threaded ring with 2 holes)needs to be watched to prevent unthreading. It can be secured with Loctite, but do not overtighten and overload the bearings.
bill sams
>Thanks Jamie, you confirm my skeptical thoughts of the "one-way copies".
Re:I had a discussion about this .....
Jamie Donaldson
>....very situation with Kevin (of Oneway family) at SWAT, as several people that purchased the knockoffs had a similar problem. I believe he told me that Oneway had won a restraining order against Jet for trade law violation.
