tool handles
tool handles
tool handles
keith zimmerman, Normal IL
>I just read a post from Jorge Castaneda about his turning his own handles and using setscrews. I like the idea of doing this instead of gluing the shaft of a tool into a handle.
What technique do you guys use to make a handle this way? I have tried to figure it out, but it confuses me.
Thanks in advance.
keithz
Re: tool handles
Re: tool handles
>Keith I've only done a few like this. I use what are called pipe nipples. Basically thick brass pipe. You can get it in various ID's and lengths. I cut it to the proper length and then true up one side on the lathe. The true side goes into the wood. The other end will be trued up after it's glued to the handle. These are thick enough that you can tap threads into them. After I've turned the handles I drill and tap the brass (and usually a little wood) Then I put some thin CA on the threads and run the tap through again. Make sure your set screws are long enough to engage the brass.
Re: tool handles
Mike Stafford
Re: tool handles
Mike Stafford
>Keith, I have been converting all my favorite tools to use handle adaptors that allow the length of the tool's projection to be changed and also allows the tool's cutting edge to be inserted inside the handle to protect it while traveling. Now my tools are easily recognized by the wood I use for the handle.
Dennis Yoder frequents WC and is able to make them as are some other people. I have included a picture of some for you to see. Basically you drill a hole to accommodate the shank of the adaptor and glue it into the handle. Then you can fix the tool shaft with the set screws.
I love my tools with these adaptors in the handles. If you have a favorite handle you don't have to get rid of it just because the tool is worn out. Replace the tool and put it in the same handle.
Re: tool handles
Here's a link to CSUSA's product
David Walser
>For those looking for a ready supply of the handle insert's, here's a link to CSUSA's version. There are other suppliers, but this link was handy for me.
Re: tool handles
Re: The Hosaluk handle inserts are .....
Jamie Donaldson
>.....less expensive ($19.95) from Packard- packardwoodworks.com
Re: tool handles
Re: tool handles
Terry Quiram
>Keith
Come up some Saturday and we can make all the handles you want. We can get the steel from the blacksmith shop.
Terry
Re: tool handles
Mike Stafford
I think Dennis' adaptors are even cheaper ....
Mike Stafford
>I will not speak for Dennis but I think he is selling his adaptors for less than $19.95 each.
Re: tool handles
Re: tool handles
Chuck Engstrom
>Hi Keith -- I've made a few using copper tubing fittings (see photo). This avoids marring the tool shaft with set screws and gives you a bit quicker change-over process if you want to use the same handle for several tools. And there's no little Allen wrench to lose in the chips, just a big old wrench if you need to tighten more than hand-tight.
I did have to bore out the fittings here and there to accommodate some tool shafts, which are not always exactly the specified size. Sizes shown are 1/4, 1/2, and 5/8 inch.
best to all--
Chuck
Re: tool handles
Mike Stafford
Re: tool handles
Mike Stafford
>So far I haven't seen any set screws that would make a dent in the high speed steel tool shafts I have.
The set screws in my adaptors use the same T-handle Allen wrench as the jaw screws for my chucks so it will not easily disappear in the wood chips.
Re: tool handles
Keith
Jorge Castaneda~Downeast Maine
>Here is a pic showing what I do, I just use a piece of galvanized pipe I had laying around, cut a small section, bore the blank, shape the handle, fit the ferrule and drill and tap, presto! I CA the ferrules to the handles.
One of the advantages of doing my handles this way is ease of sharpening as I said in the other post, but there is another just as important: for each diameter, I made 3 handles, long, medium and short, so the same iron can be used in three different configurations, a win win situation.
Go for it!
Jorge
Re: tool handles
Re: Keith
>forgot to say, the Allen wrenches live in a magnet on the leg of the lathe, never lost one in over two years.
Re: tool handles
carl
Re: Keith
carl
>Now why didn`t i think about Magnets. Is the hole bored into the handle to accept the fixture that is secured with c/a strong enough to hold the whole assembly together while turning.? Carl
Re: tool handles
Re: Keith
>Carl,
Yes, it is, some of my gouges are huge, like the 1 1/4" SRG in the picture, and I have also 3/4", several 5/8", 1/2" and 3/8" and none has come undone.
I turn many big bowls and as I don't have a band saw, the blanks are very unbalanced and the big ones do the job.
Jorge
Re: tool handles
Dick Hines
Re: tool handles
Dick Hines
>Chuck, I have only made a couple of handles but you have a great idea. If I make another handle I will give it a try.
Re: tool handles
Dick Hines
Re: tool handles
Dick Hines
>Mike my Kelton hollowing tools have dents all along the the tool. I have had them for years and work them hard. The dents don't cause any problem except for looks.
Re: tool handles
Re: I think Dennis' adaptors are even cheaper ....
Dennis Yoder
>When I recover from my 8th back surgery (7days in ICU from complications) I will be back in the shop and making inserts and full tool handles once again. Yes Mike they are much less $$ than $20. Dennis Y
Re: tool handles
Mike Stafford
Get well soon....
Mike Stafford
>I had forgotten about your surgery Dennis. I was just bragging on the adaptors I got from you and wanted everyone to have a chance to use some if they wanted.
I wish you a speedy recovery and have a Happy Thanksgiving.
Give my best to Christine.
Re: tool handles
Re: tool handles
Clay Foster
>This is the handle I've been using for almost 20 years. It was turned from an old bois d'arc fence post, a 5/8" hole drilled in the end for a 5/8" bowl gouge, four saw kerfs down the sides, and a hose clamp to secure the gouge. I keep a nut driver handy to loosen and tighten the clamp. It's quick and inexpensive.
Re: tool handles
Re: Yes Dennis, get well soon...., so ...
Jamie Donaldson
>... I can order some of your adapters to go with traveling handles I'm using!
Re: tool handles
Re: I like the "color scheme" of your ....
Jamie Donaldson
>... silver adapters that match the tool steels. After so many years in photo labs with all the stainless steel equipment I'm really into silver matching components!
Re: tool handles
Expect an email from me tonight
Re: tool handles
Thanks everyone
keith zimmerman, Normal, IL
>You gave me lots of ideas for making this kind of handle, and I thank you.
keithz
