Finish - Sanding Sealer/MineralOil, 50-50Lacq/MO
charlie belden
>During Jimmy Clewes demo, he had an english walnut shallow bowl turned on the outside and rather than use just mineral oil to pop the grin and serve as a finish, he asked what the club's favorite finish was. The answer was Deft Sanding Sealer, light sanding and an application of Deft lacquer cut 50-50 with lacquer thinnner.
He sopped the 50-50 on with a paper towel and wiped off the excess - again with a paper towel - talked about finishes (there is no One Perfect For All Woods finish) whilel the lacquer dried - then applied a coat of mineral oil. Let it sit for a minute or two then wiped off the excess.
Club members were slightly aghast! Mineral oil - over lacquer, even cut 50-50?
Does THAT work for you Jimmy?
Don't know if it will or not - this is a first try at it.
Actually looked pretty good - better than just a coat of 50-50.
Clewes then tried the sanding sealer on the inside, hand sanded lightly - and applied a coat of mineral oil. Wiped the excess off after a minute and buffed by hand with a paper towel. The results were better than the 50-50 then mineral oil - and really quite nice looking.
That finish going to hold up? asked an attendee.
"Don't know, but I'll be gone before anyone finds out if it works or not." says Jimmy with a grin.
Now I know that mineral oil is used as a lubricator when buffing out a french polish, with or without rotten stone or pumice. And I know that just mineral oil on a raw wood bowl will pop the grain some - if there's anything to pop. Not sure what mineral oil over sanding sealer or lacquer cut 50-50 does - but it did pop the grain a bit over sanding sealer. How it holds up? No idea.
Anyone used mineral oil over any other finish - successfully? If so, what undercoat?
