Water Based Lacquer
Water Based Lacquer
Water Based Lacquer
Devon Palmer
>Greetings,
Does anyone have any good info, or links to application and finishing techniques using water based lacquers? Any brand testimonials?
Warmest Regards,
- Devon Palmer, Columbus Ohio
Re: Water Based Lacquer
Re: Devon- I can recommend the ......
Jamie Donaldson
>...General Finishes "High Performance" H20 based finish, but it is a poly rather than lacquer material. It dries in 2~4 hrs. to a hard and clear finish.
russ fairfield
>A fellow woodturner, Charlie Benson, and I have been using the new waterborn lacquers that burn into the underlying coats similar to the nitrocellulose and CAB Adrylics. Charlie Benson has had excellent results with spraying the waterborne lacquer by Target Coatings. I have been using a similar product from Stewart-McDonald, the luthier supply folks, as a brushing and wipe-on finish. There isn't much to say about using them other than - follow the directions on the can.
These lacquers are among the hardest finishes I have ever used on a piece of turned wood. They are much harder than the nitrocellulose we are used to. That makes them much more difficult to use as a brush-on finish because they are more difficult to sand and polish. A very soft 3/4" artists sable hair mop brush leaves the fewest and shallowest brush marks and is therefore the fastest to sand smooth and polish. Sanding between coats is necessary because subsequent coats make the underlying brush marks only bigger.
As a wipe-on finish, I haven't figured out the right combination of thinner and retarder to get a smooth surface with a rag. You are welcome to try the wipe-on, and you may have better luck doing it than I. I recommend spraying these new lacquers, and brushing if you want to take on the chore of smoothing and polishing the harder surface.
It is too soon to tell anything about color change, long term durability, or if they become brittle with age. So far, their clarity is equal to the other lacquers, and they won't yellow with age. However, like all waterborne finishes, they don't accent the grain as well as the solvent lacquers. A smooth perfect surface, sanded to at least 600-grit is a must. The waterborne lacquer accents and magnifies sanding scratches and torn grain more than any other finish I have ever used. The smooth polished wood will also contribute to accenting the grain.
Devon Palmer
>Many thanks for the responses.
Would a few wash coats of dewaxed shellac help pop the grain? I'll have to give it a try and find out.
- Devon
Keith Tompkins
Keith Tompkins
>Hi Devon, you would have to experiment with that..I would be afraid the shellac would be affected by the water based finish. These water borne finishes are designed to be sprayed with a HVLP system; we use a DUX system which is expensive but works well. A sanding sealer should be used with this finish.. the water based finish raises the grain, and the sealer sands far easier than the top coat. Coat, sand, coat, sand until the finish no longer raises the grain. It's possible to apply heavy coats without sagging, in fact, the coating should appear white with a blue tint when wet. My big complaint is the wood has no "pop" with these new finishes.
bob davis5098
>i have used highland hardware[woodworking} water based resistane fsince the mid 90s mostly brush on flatware, but use it occasionaly thinned with water as a wipe on for a turned piece such as holly when i wanpreserve the light color..very durable
