>I should have done a more thorough search, but couldn't think of decent keywords to use...
I'm still trying to get the hang of turning a nice, even cylinder, or an even taper. Something you can lay a ruler on, and see that it's more or less straight, and clean. I'm thinking chair and table legs, mostly, and bed posts. Not exactly exciting stuff, but I like to keep things simple.
Any suggstions? Books, other sources? Or is there something I'm not thinking out properly?
>James I do that all the time. A perfectly straight cylinder is the hardest as well as something that needs to be really accurate like a Morse taper. Fortunately most things only need to look like they are accurate.
What I do is take a parting tool and a set of calipers and make parting cuts just a little shy of the actual size I want. It if has to be perfect I make the cuts pretty close together. If not I space them apart. Then it's just a matter of taking the wood down in steps until you can just barely see all the parting tool marks. Then make one more pass to clean up all the parting tool marks and make the cylinder true. I use a skew for that now days but in the early years I used wide spindle gouge. I still have that gouge, it's about 1" wide and sharpened to about 35 degrees so it cuts similar to a skew.
To do an accurate taper measure the diameter from a drawing. Make marks on the drawing about every inch. Then transfer these to your blank using the parting tool to cut down to the depth at each distance. Then just connect the dots so to speak by turning away the wood until you get down to the parting tool cuts. For tapers you might have to angle the parting tool perpendicular to that particular part of the taper.
>James - here is a technique that I've used to make highly accurate 16" x 4" dia. cylinders.
Turn 2 or 3 very carefully measured diameters - each end and one in the middle. Turn them slightly higher than what you are shooting for. Turn the rest down to these points by eye. Do this step anyway that works well for you.
When I am approaching the final diameter, I take a pencil and lightly run it the full length of the work while the lathe is running. I then take a stick that I've milled straight and flat with sandpaper wrapped around it (psa or tightly stapled etc)and hold it against the cylinder (using the stick as a sandpaper straight edge). A light touch will sand the pencil marks off of the high spots.
You then go back and with a gouge or skew and take "a little more" off of the the spots where the pencil sanded off. Depending on how much the sanded spots show up you may not even need the pencil.
I've used this technique to make the tube parts for my Cryptex Tantalus - a locking wine holding box. It might be overkill for furniture parts.
>the edge of your tool rest next to the wood and jamb it into the wood while it is spinning. A 12" wide scraper/skew. Just kidding.
I agree with the guys above. I use the Caliper and parting tool method. Part of it is practice. I find setting the tool rest parallel to what I want to be a big help. So, I rough it down and once I'm close I carefully make the rest parallel tot eh cylinder. Then I can use the skew or gouge and I clamp a finger on the tool at the right distance and slide it along the rest, just taking a shaving.
Setting your light so that it shines even on the cylinder also helps.
Another thing I do is in the sanding. Several years ago I lucked into some sandpaper that has heavy backing on it. About 8" wide in several grits about the same weight as belt sander belts. Once my cylinder looks pretty good, I wrap a piece of this sand paper around it (not all the way around, but about a 1/4 of the way) and pull it tight. It sands away the high spots. The sand paper rips easily so I make the piece about an inch narrower that the cylinder and slade it left and right. Sort of shoe shining it.
Look up Entasis, its the concept that a true cylinder does not "look" true. they might look better if they are slightly concave.
And part of it is.....Practice. Practice. And did I mention PRACTICE.
>I was trying to give you an accurate way of doing it. My dad uses a belt sander on large areas. He isn't as picky as I am. He cuts is sort of close and then holds the beltsander against it to clean up all the tool marks and make a long flat or tapered spindle.
You can use a hand plane but I found that it's easy to get tearout with them. It also dulls the hand plane blade and then it doesn't work for it was designed to do, which is plane flat boards. If you try it use a block plane.
>...lining up your toolrest so it is parallel to the ways, and using your skew, ensure that there is even space between the cylinder and the rest? It is close enough for jazz (as they say) and MOST things you seem to want to do. Break out the calipers when you need to make a bunch the exact same.
>Get it somewhere near using any tool you are comfortable using. Then take a sanding belt and cut a piece of 3/4" plywood to fit in the loop of the belt. Radius the ends so there are no sharp corners. Try to get a tight fit and make the ply the same width as the belt. Hold the sanding block length along axis and sand moving the block side to side. Start with about 80 grit and work your way down to 220. Never wrap sand paper around a spinning cylinder because if it grabs you can sand your fingers down to the bone. DAMHIKT.
