Corian anyone ?
Corian anyone ?
Corian anyone ?
jim miles - Charlote NC
>I am thinking of using Corian or similiar material in some of my segmented & staved pieces. I think it could add some interesting effects - especially the colors. Anyone have experience with this material? How would you glue it to wood? Where do you get larger pieces?
Re: Corian anyone ?
Re: Corian anyone ?
D. Hansen
>It is a "plastic" type material and glues to wood fairly easily with any of the regular glues. Corian also has a special glue that will allow you to join pieces together. You can get pieces from any shop that makes kitchen counters. The one I use had cut offs and cut outs from counters for sale just to get rid of it. Most of the pieces available are about 1/2 inch or so but you can glue it with the corian glue and it does not show any join marks just sort of melts itself together.
Re: Corian anyone ?
Re: Corian anyone ?
Jeff
>I used to work at a Corian shop and at times we would actually use super glue to glue pieces together. I have turned a segmented vessel that had corian and wood in it, I used super glue on everything and it worked great.
Re: Corian anyone ?
Re: Corian anyone ?
Dick Coers
>I haven't used it in combination with wood, but I would think that you would have to be very careful during sanding. The corian would sand at a different rate than the wood, and may stand proud of the wood when using the very fine grits.
Re: Corian anyone ?
Re: Corian anyone ?
Texian
>You will want to be mindful of potential issues with wood movement due to temp. and RH changes, with respect to the relative stability (?) of the plastic.
Re: Corian anyone ?
Bob Moffett
Re: Corian anyone ?
Bob Moffett
>What type of glue is best for gluing pieces of corian together when you don't want to see the seams?
