vacuum chuck set -up
Paul Woelper
>are there any ways to hook up a vacuum pump on the cheap, it seems any bearing kits from the catalogs are all 60.00 or more. thanks for your help! Paul
Re: vacuum chuck set -up
Re: vacuum chuck set -up *LINK*
Mike Foster
>I have pictures of my version of a home-made vacuum adapter that allows you to connect the vacuum tubing, or remove it in seconds and use a knock out bar through the adapter. I have a couple of pictures on my website, and a link to an incomplete article that I wrote with intentions on submitting it to Woodturning magazine but never really completed it due to some major computer problems where I lost the pictures that would accompany the article. Still may give you some ideas.
http://breezyhillturning.com/Tools_and_jigs.html
MikeNelson
>We have a 'Purvis Bearing here in corsicana, they have sealed bearings for less than ten bucks. I pull about 23-4 if the woods not leaking, which is more than enough to clean up a bottom or whatever. Don't buy so-called sealed bearings from other local outlets. You shouldn't have to pay more than ten for a sealed bearing.
Gil Jones...GA
>You could use a strong shop vacuum, but it would probably need to have a separate motor cooling air supply system.
Jorge Castaneda~Downeast Maine
>Actually, Teknatool sells an adapter that fits their lathes and is to be used with a shop vac, the adapter lets air in...
about $30.00
