Electronic Speed Control for Jet?
nick
>Does anyone know a way to slow down a Jet 1236 (with Reeves variable speed), maybe with new, dc motor? The minimum speed now is 500 rpm but 200 would be useful. Any suggestions?
Re: Electronic Speed Control for Jet?
Trade-up to a jet 1642!
Dave Anderson (PacNW)
Lan Brady
>It can be done. The motor has a frame type printed on. You need that information. I had the Jet 1442. It had the same reverse mounted motor. If you install a longer motor, it will reduce the size of bowl/vase you turn on it.
I gave up and bought a bigger lathe.
Lan
bernie feinerman
>You could either replace the motor with a DC treadmill motor and speed control, or add the treadmill motor/controller as an auxilary power source.
It is not easy. Some parts are available from Surplus Center. I started putting a treadmill motor on a Jet 1236 and am not finished. So far, I expect to retain the Reeves drive intact so as to be able to sell the 1236 without the treadmill motor system if I ever upgrade to a bigger lathe.
Re: Electronic Speed Control for Jet? *LINK*
Philip Morris
>Nick,
The attached article shows a way to add an additional lower speed to a Jet 1236.
There is also a way of shifting the detent ring and moving all six speeds lower (no drilling required). I tried this on a 1236 I once had and it definitely worked.
If you want to get a sense for the amount of reduction, just move the handle to release the detent pin and push the handle as far down as it will go (you will find that it goes a fair ways past the slow speed stop).
The only regret to this approach would be additional belt tension, which will probably result in increased belt and possibly bearing wear.
With all that said, IMHO I would not spend any serious money trying to install electronic variable speed on this lathe. I think you would be better off selling the 1236 and using the money to purchase either the variable speed version of the Jet 1220 or new Delta midi.
While I had the Jet 1236, I purchased a Jet 1220VS. I put the same out of balance blank on both. Even with the modification described above, the 1236 had significantly more vibration at its low speed than the 1220VS had at its low speed. BTW, the 1220 was just sitting (not bolted) on a benchtop. The 1236 had 300 pounds of gravel on a shelf in the stand, along with panels attached to the stand to make it stiffer.
Jet 1236 Low Speed Modification
Lyle Jamieson
Lyle Jamieson
>Dont know if it will work on the Jet, but I did exactly what you want on an old Powermatic 90 with reeves drive VS. I reduced the pully size on the motor shaft. This will reduce the entire range of speed within the reeves drive range. Slow will be slower and fast will be slower.
bob davis
>i did that on my general 160 but do not think it is feasible onthe jet. a different pulley set up
Nick
>Thanks. I'm going to try it.
