Really big boring bar
>This is the largest one I've seen. Thought you would enjoy it.
Anatoly Tsiris and his workshop. I believe he's from North Carolina.
That's a big bar and a lot of padding..
>At least I'm presuming it is padding under his arm.
A catch puts your head through the ceiling
steve antonucci
Re: A catch puts your head through the ceiling
jfox442
>Pretty good sized steady rest too!
And your ribs six feet under ground
Jorge Castaneda~Downeast Maine
Re: Really big boring bar
Dick Coers
>No shoes? And I thought I had trouble getting a range with my bifocals now. I might not even see the opening at the distance he works.
Re: Really big boring bar *LINK*
Raymond Overman in SC
>Yep, Anatoly's is in Charlotte. Great guy and a good friend. You can see more at his web site.
Anatoly Tsiris
Oh, and he was working on one of his small pieces
>in that picture.
Re: Oh, and he was working on one of his small pie
jim miles - Charlote NC
>Ray is right! That is one of his small pieces. He does vessels 5 feet tall and 3 feet wide -- big enough for a small man to get in!
Doug Thompson near Cleveland
>Anatoly saw the 1 inch Texas size bowl gouge at the Greensboro show... most think a 3/4 is big but Anatoly wants the 1 inch.
BTW - his work is outstanding.
Don at Central Illinois
>I think those are wooden shoes, not bare feet.
Lyle Jamieson
>I hope nobody else tries this. He is putting himself in significant danger. The back rest MUST has a safety bar accross the top of the boring bar. AND!! the back rest must be attached to the lathe. See my new Giant bar for the safe and only way to go bigger. Lifes too short to risk getting hurt...seriously hurt. This is no joking matter!! Lyle Jamieson
Looks like he could use a vac on that bar
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I have not been doing much turning in a while, nor been to this site. Have you developed your vacuum hollowing tool yet?
I was wondering how large the cutting tip is on that tool?
Re: Looks like he could use a vac on that bar
>If I'm not mistaken the cutter is 1 1/4 inches square with a rounded tip just like any other boring bar. The end is articulated and can be changed to get under shoulders.
>Lyle,
The bar is "captured" at the tool rest end to arrest any torque. The bar weighs around 145# and he can hollow to a depth of 3'-4' easily. He does have a stop pin in the bottom of the bar to let him know when he's near the end on the rear rest. From where he is, he can't adjust the angle of the boring bar. It travels in a plane dictated by the height of the tool rest and pivots on a point at the tool rest as well.
I'm not sure where putting a bar over the top of the rear rest is going to improve any safety and the rear rest is heavy enough that it's not going anywhere with an easy push or pull.
Lyle Jamieson
>OK, Sorry, Its not as bad as I thought with the gated captive front tool rest. I have seen a lot of people doing some dangerous things with unsafe tools.
