Yew Beut latest turning
Tery Scott
>Yew Beaut
I was going to call this Some thing special after my last post of Nothing special
But I think Yew Beaut is more appropriate
After seeing all of Eugene�s Yew root pieces I have had a secret wish that one day I might find a bit of yew. When visiting a woody mate I spotted a narly old piece of root under his hedge. I enquired what it was. When he replied it was a Yew root and he didn�t know what to do with it. I volunteered to take it off his hands in exchange for a piece of Kauri.
He thought I was crazy as this was destined for his fire heap.
This is the second piece I managed to make from the lump of dirt in cased yew.
This stuff was definitely out of my comfort zone as it was bone dry and as hard as a rock. I have never tried Pewter work inlays, another comfort zone adventure.
I finally managed to buy some casting pewter 2kg of the stuff in a big block.
I thought I had been didled as when I tried to heat it wouldn�t melt; it took me a while to realize the block was acting as a heat sink and not getting hot enough.
A few cuts into thin slices on the band saw and I was finally away.
The voids were undercut with the dremel before I melted in the pewter with the aid of dams being made with aluminium tape. Then with a soldering iron (had to go and buy one of those also the old electric type with a large head as my gas heated one burnt the wood before the pewter melted.)
I had all sorts of fun trying to get the pewter in the voids it was like playing with liquid mercury, went everyway but the way I wanted it to.
Next I cut the pewter back to the wood and started to turn out the inside.
I wanted a � inch wall thickness but didn�t quite get to that as some of the pewter started falling out into the inside. Back to the drawing board, I managed to get inside with some surgical tweezers and put on some tape so I could recast the pewter.
I super glued in all the suckers as well this time .The inside is sanded to the same grit as the out side with my new toy a free wheeling sander from Woodcut.
A Coca bola finial was fitted; I have been saving this my only piece for a special occasion.
8 inches high A first for me as I finished with oil then waxed and buffed
Definitely out of my comfort zone
What do you think
Re: Yew Beut latest turning
Steve Kubien
Steve Kubien
>I don't care how comfortable you are, this is gorgeous! Well done Terry.
Carole Valentine
>Definitely a beauty, Terry! You said you superglued the pewter in...I am confused about how in the world you did that? Did you pop out the pewter after it had cooled, apply glue and re-insert?
Keep on playing...I think this one is the beginning of a series!
Mike Brazeau
>This is a beauty Terry. Thanks for tip on the Aluminum tape for backing up a hole. Have been wanting to try some pewter inlay for years. Clipping this one away for future ideas.
Mike
keith zimmerman, Normal IL
>Finally, an inlay that appears balanced on the piece. Too often, I see people using inlay in only one or two areas of a piece. That just doesn't show any balance and, in fact, makes the balance of the piece appear off. This is the exact reason I quit using inlay to fill voids.
This one doesn't do that.
And it looks good too.
keithz
Sounds like a PIA but worth it
Mike Foster
>I love the bands of pewter on top, how did you cast them solid? The twist on the finial is exquisite. Very nice piece.
mike
Awesome!
Jorge Castaneda~Downeast Maine
>Terry,
A beaut all right,
Thanks for sharing
Jorge
