Warped blank question
>I should know this, but I don't seem to recall. (CRS?)
If I rough turn a wet blank and get a bowl that is 12" in diameter and a little over an inch thick, when it dries and warps to an oval, will it be something like 12 1/2" by ll 1/2"? In other words, longer than it was originally or will it be something like 12 by 11. (not longer that the original diameter? I have some walnut blanks drying. Just wondering.
Re: Warped blank question
>Depends on how it was cut from the tree. If you assume that it is a side grain vessel (grain runs perpendicular to the bed of the lathe) and the grain was balanced. it will warp somewhat evenly into a football shape. The pith areas will get longer and stick up while the side will get shorter and move down. That's how the hat turners get their hats to fit our non round heads.
Appearance versus reality...
>I think that if you put a tape on your blank, you might find that the actual difference was somewhat less. For a 12" piece, it might be only 1/2" (12 1/4" x 11 3/4") - it just looks like more. I've always been surprised at how little you have to take off to round them up again.
When I have green turned leg blanks (2" turned dimension), they typically go out of round by about 1/16 to 1/8" at the 2" bulb. Your eye can usually see about 1/32" of difference.
Warp varies with species as well
>I have some rough turned Wysteria bowls that are so out of round they cannot be put back on the lathe. I will have to carve them.
Re: Warp varies with species as well
Wally Dickerman in Arizona
>It does depend on the wood. Mesquite, our most stable wood, moves very little. Pacific madrone, our most unstable wood, will do crazy things. I once thin turned a wet medrone bowl and just let it do what it wanted to. It ended up looking a lot like a hospital bedpan.
Wally
I haven't seen a turned bedpan-scary image
another craft show possibility
bob davis
Leo Van Der Loo
Leo Van Der Loo
>Wood does not get longer, you can't stretch it either.
The sides will get thinner, and shorter in circumference, so it will pull on the ends and become lower on the sides.
Depending on how much heart and sapwood you have and the species, the amount of distortion/shrinking will be different, most are in the 8% to 12% area in the circumference shrinking.
All this is assuming sidegrain turning, not endgrain.
charlie belden
Don't recall the DaDa artist, but he hung a white porcelin urinal on the wall and titled it "Fountain". You could call you madronhe bedpan piece "Pool" - and it would have made about as much sense under the last administration as "Fountain" did during the insanity of the first World War.
Barry Turner
>Keep moving those Wisteria blanks around the shop. If they ever take root, you'll have to burn your shop to stop it.
