shavings for calla tubers
Thad
>I know the issue of shavings for mulch has been mentioned, and I know to stay away from walnut.
I'm getting ready to lift calla tubers for the winter, and was wondering if anybody here uses shavings to store them in to keep dry.
I would assume that using spalt-free domestic shavings would be best.
Anything else I need to consider?
~ Thad
Middle GA
Re: shavings for calla tubers
>In addition to staying away from black walnut, you may consider staying away from wood that is rich in tannins. I don't know if tannins would have an effect on calla tubers.
Rob Wallace
Re: shavings for calla tubers [OT]
Rob Wallace
>Thad:
I assume you mean the use of wood shavings for the overwintering storage of calla tubers that have been dug out of the ground.
As long as the wood shavings are completely dry, and the tubers will not be in active growth during the storage period, almost any wood species can be used. (I suppose even dry walnut shavings could be used, as long as the shavings remained dry, and the juglone found in the wood was not dissolved in water and come in contact with the tubers, but I wouldn't advise this!). Even shavings of woods high in tannin (like oak) could be used as long as the shavings are dry and remain so throughout the storage period (tannins also need to be dissolved in water to become chemically "active" to possibly impair or stunt growth).
Wood species like maple, oak, ash, box elder, mulberry, or other 'neutral' species should work OK in this application as long as they are completely dry before storing the tubers in them. I agree that staying away from spalted wood shavings is a good idea to reduce possible fungal damage, although most of the fungi that are part of the spalting process likely would not develop pathogenicity problems with the calla tubers (many of these fungal species are probably in the soil around the tubers throughout the summer anyway!).
The key is to maintain the tubers in a cool and dry location; the wood shavings help by absorbing any moisture given off, and dissipating it into the air. Do not store them in completely closed containers.
Good luck!
Rob Wallace
